the terrible turning circle, sitting low in the bucket seats its hard to view the dimentions of the car to clear stationary objects etc.
+1 to both. I could turn a 60's Cadillac around in less room than my r33. I am 6' 1 tall and can only just see over the bonnet, the form of the bucket seats makes it hard to sit up and have a good posture.
  • Replies 101
Compared to a golf v diesel:
Interior light can be left on and it drains battery, it doesn't time out. mine times out on alarm circuit after a few min
Car can be locked with second keys in the ignition. yep stupid design, still find most cars are like that
Window wiper spray is like a 2 year old peeing, vs a carthorse. yep you would think they would put sprays on the wipers arms not bonnet
When you go into reverse in the rain, the rear wiper doesn't automatically run. would be a good idea wouldnt it ?
When you wash the window, the wiper doesn't do a second sweep 10 seconds later to clear the drips. true
You can't close all the windows by holding the lock button down. (or open them all) true but use two fingers instead ?my alarm rolls mine up when it arms ,sunroof and mirrors too?
There is no trunk release on the remote. my alarm fixed that up
When it rains the wipers don't start alarm will do that for me as well, but dont like it either
When you go into a tunnel, the headlights don't turn on. my alarm can do that for me but i dont like it
You can't operate the radio with the ignition off. who would want too? the amps would drain my battery in min.lol
The doors don't hold open in either of two positions, on steep sydney streets. agree tired of kicking them open in wind so i dont get wiped out
The fuel economy for just short shopping trips is 25l/100km instead of 5l/100km its a bit wonky, sometimes good sometimes its like a hole in fuel tank?
It is a barge to park and seemingly every bit wants to rub on a curb or speed bump. yep cant see behind you good= C pillars
You can lock the car and get a blinker flash even if a door or trunk is not fully closed. yep agree, but i put in a second alarm to override the annoying bits.
No cup holders, no map reading spotlights, no night-time red cabin illumination. small cupholders in console /mines has all blue led and neons now
There is no torque at 1500 rpm vs 300nm of torque in the golf diesel. I agree only my RB25det is worse..lol
2000 R34 GTT series 2
and the tire whine from rear tires
or the annoying rattles in the car, mine has 47,000k on it and it seems like 400,000, even with dynamat sound deadener and spray coating on all panels ? sunroof model ?
leaky windows in front in when you spray the windows with hose
drives like a truck on bumps, annoying bounces with coilovers and bad roads.
so stiff the inner rear tire comes off the ground when you pull into driveways , looks odd ...lol
lousy 5spd box, noisy and bad ratios.
seats stain with a single rain drop, silver inserts parts. wears bad too.
seats sit to high for 6ft people. and why bother with a back seat you would need no legs ?
front brake rotors warp if you look at them wrong, factory pads leave the white wheels black after short trip.
wimpy little caliper in the rear brakes
tires wear fast on front
whining power steering
noisy lifters after a few min to heat up
no cruise control on jap cars imported from there ,but in usa its standard ?
taillight bulbs burn out easy and need to take out a lot of bolts to get to them ?
whimpy battery and connections from japan
idle is a bit wild , hunts around a lot after driving
broken bolts on turbo manifold common, had mine break already at 47,000k
traction control switch is hidden under my knee, not in open spot, when it comes on its dangerous sometimes, power loss is wild
turn signal shuts off mid corner if the round about isnt perfect corner
original sat nav.tv, MD, CD changer / DVD player was absolute garbage thinks in northern hemisphere still, written all in japanese, gutted all of it ..lol
3 child seat bolts, is that oz standards?, come on how would they fit ...lol
oil filter is in bad spot
so is the power steering fluid bottle
RB block design, 1 bolt holds the tensioner pulley to block, had one shear off on RB30 motor at idle, great fun to fix without draining out A/C had to retap block.
tiny intercooler ? heat soaks easy in adelaide traffic
the mirror inside blocks my vision in roundbaouts cant see a car behind it, needs a better design on all cars. like my old multi-panel mirror in my RX7 for racing worked way better.
lots more little bits but for the most part im very very happy with my car and the other skyline R31 i have is still running fine at 485,000k on it so they must be ok, but my RZ TT supra is better to drive.
my new work car 2007 camry is way worse go figure?lol
with todays hi tech you would think they could figure out some things better...lol
1994 R33 GTSt
Friggin massive C pillars make doing a head check pointless as you can't see if a car is in your blind spot anyway
+1, every time I turn onto a main road that requires me to check the left rear side, I have to 1st get my car in a weird angle to see the traffic from the road properly...
As or the turning circle, maybe its coz the only 2 others cars I have driven for extended periods of time was a 91 Commo & a 02 Camry, turning circle of the R33 seems better compared to those 2.
Edited by Mayuri Krab
yeh turning circle in an r32 is pretty bad also...i always get scared when i do a u turn that i won't make it and will have to reverse against on coming traffic LoL.
also i've been trying to use the aircon in my r32 and is it my car or every 32 that the fan on the 4th option doesn't blow air as good? took forever for my car to cool up. might be the air ducts not in position?
yeah i've noticed the air con thing too... the highest fan setting doesn't do a whole lot more than the 3rd... gets cold really quick :P but the air stinks!! must be some old japanese noodles stuck in the ducts or something.. man it's bad
Car: 1989 R32 GTR
Hate all the stuffing around it takes to get an import car registered in nsw. Probly mostly the RTAs fault cause they are a pack of people who dont know sh*t (its done now so its ok)
Hate the fact that my alternator blew up (surged) and shorted out most of the relays / bulbs and stuff in my car causing a major headache.
Other than that I love the powaaa of the rb26 and great handling / drivability of the gtr!
Also I don't like the R33's climate control unit, where if I turned the whole dam thing off, I can't turn it on with fan only without 1st having to turn on the A/C (have to press "auto" to turn the unit back on then press the fan speed so it doesn't blast at me full speed... also I don't like the fact that it doesn't "remember" my last mode, every time I turn it off then on again, it always goes back to blowing air through the top vents & I have to cycle through the whole thing again. Would prefer a much simpler manual A/C control until like the ones found in regular Camrys & Comos.
Actually, you can. Just hit the 'mode' button and you'll turn it on with no fan, or the fan button to switch it on with just fan (no A/C)... I think....
I hate that my car isn't a JZX100 :P
But seriously, I have a 89 R32 4dr. Things about it that piss me off:
shit turning circle (and lack of lock when sliding) - have since rectified this somewhat with steering rack spacers
fked bushes - again have rectified that and it drives a lot better now
rattles & squeeks everywhere
the vibration it's geting between 2.5 and 3k rpm, which is the range i use 90% while cruising :D
speedo doesn't work
has no torque
has no air con
being a 4dr, the B pillar is more forward than a 2dr, which gets annoying at times.
and what I hate about skylines in general is the image thats associated with them. FFS, I drive my car to get from one place to another. I don't get in it to hoon and cause mischeif and piss people off, and I certainly don't like being pulled over for no fking reason other than the car I drive :banana::D
hmmmm...
...sounds more like a P76 or a Stag S1
The clicking that comes from the air con on anything above 18 degrees!
that age old blend door actuator problem.
stupid little problem but damn it shits me.
Ah yes... that's very annoying... does anyone know if there's a how-to or a thread write-up on fixing this?
The sun visors are too small.
No passenger handle bar on the ceiling (Or I call it a 'Jesus' bar, cuz when you take off, ppl grab that bar and say "Jesus frikken... were going so fast...)
I wish it had better fuel economy.
Easy (but not cheap) way to fix seat room for people over 6 foot is to put GTR seats in GTST - makes it much much nicer and lower.
R33 GTST:
My 2 big issues are:
1. gear ratios.
1st gear too short, 5th gear too short. (Need OS Giken 1st and custom 5th)
2. Tyre roar - just too much. Might have to spray with sound deadening.
Turning circle is pretty good compared to Clio Sport.
I find the ride on bilsteins with front sway bar on medium and rear on soft is pretty damn good for a 10 year old car.
  • 4 weeks later...
Yeah there is but I dunno the shortcut atm... has a guide on where to reflow the solder. I did mine 4 weeks ago and its been running like a dream ever since :)
As to what I hate.... diagnosing HICAS issues.... not being able to have sex in the back seat because im not a midget (and those bucket rear seats, ouch) um, the rarity of mechanics that actually know what theyre doing.... hard to find replacement bits sometimes
but on the whole i still love my gtr ;D
-D
No mirrors on the visors but with the electric folding side mirrors you can stop them halfway and check yourself before hitting the scene.
Or adjust the mirror to have a perfect view of your girl passengers cleavage.
I always drive with the window open so..
Poor roof channel/gutter design, it's almost as if they designed it to flow rain into the cabin.
Might have to get some gay deflectors some day.
No faults other than that, just keeps ticking away.
R32 gtst coupe
Everything is okay cept the back seat doesnt fold down and is a bitch to get in and out.
Other then that everything is perfect. yeee boiiiiiii GO THE 32s :blush:
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
