Hey Marko I was looking at going the Tomei Expreme manifolds but my mate at HKS jumped up and down and said to stick with standards match ported and polished.
He had done alot of their top cars including their Drag 33 and said no reason whatsoever to go with anything else and why change something that works!
that is good hear + they will never warp/crack
  • Replies 286
Throttle body manifold also getting the port/polish treatment
Engine assembly room kept at constant temperature
More match port/polish
Garret hairdryers -5's and Tomei dumps
Hypetune R26 Racing Plenumn fitment
Had a few dramas with this as you can see standard throttle studs too long but all good in the end!
Cams and cam gears getting dialled in
Ok motor back in the car with uprated and modified Nismo Super Coppertwin Racing clutch good for around 580kw
Also view of Tomei dumps and head oil return.
More later..........
What do the guys at HKS think of you using other Brands eg the Tomei Dumps and things like that.
I cant wait to see this car tearing up our tracks :down:
further to that - what opinion do hks have about garrett turbo's? would be good to hear feedback straight from the horses mouth
btw i also run garrett turbo's
Well every time it came down to choice of parts they would say to me .."well HKS make this part but if it was my car I'd recomend using this brand..e.g Tomei etc.
They didnt hold back on advising me what was best to use, absolutely no push to use HKS, only to use what they thought was best for the job !!
I cant wait to see this car tearing up our tracks :)
Love all the pics mate. That is one of the dream set ups I would love to have in my car, one day maybe :O Hopefully we'll see it out and about on the Gold Coast shortly.
Me too fellas, its been a long, long wait ! ..hopefully sometime in August it will all be complied and registered...
Marko they hadnt done many setups using the Garretts . They were surprised to compare the -5's to the Hks 2530's on similar setup engine dyno graphs. Garrett -5's was holding peak power for a little longer than the 2530's.
And hi octane sump extension and hypertune plenum? do they like the aussie stuff?
lookin good tho Mark! not long away now!
Hey mate hows things??
Cars all finished (well this stage) and hopefully not far off from hitting aussies shores.
I'll probably cop a bit of flack here but they definitely were impressed with the Aussie gear and pricing but...there were a few little things in finish quality that would stop them selling in Japan.
Had to do a bit of grinding to get the sump to sit up flush and had a few leaks on the welding but we sorted that all.
The plenumn...they kept stressing about the alloy being to thin and would bulge or deform but once it was on that was thrown out the door. They are quite thinner than Jun plenumn. Also the standard stud mounts were too long and they thought should have been addressed with the plenumn build.
Thing is in Japan, when your a customer and you buy a part form say Jun, Trust, HKS, Tomei, Nismo or any of the big manufacturers, you are buying something that should fit first time and with no mods. Thats the service the japanese expect !!
I think with a few of the small problems addressed the Aussie gear definitely has a right to be in the market with the big guns.
While you are at it ask them about Hypertune plenum vs Nismo?
Mike this will open up a can of worms but we built this engine keeping in mind that it was being built for power and performance but also that at latter stage I might want to go for more grunt. Right now its tuned at bit over a lazy 440kw (600ps) and with right fuel setup and turbo/ s it was built to cope for around 580kw (800+ps)
Anyway the original call was to use Endless plenumn http://www.endless-r.co.jp/pe-ji/orijinaru.htm (scroll down)
but with the Aussie dollar impersonating the peso and talking to a few crew that were using the Hypertune plenumn it made sense and finacially to go with that. Havent looked back as they reckon its super high quality and the response is awesome, the only hiccup was the dramas with mounting.
The Nismo plenumn was never on the drawing board but it would have been easier to use as with the Hypertune we had to cut a hole into the wheel fender for the plenumn piping. (Pics to come)
I think for what your going for Mike, the Nismo will be fine. You got to remember the headwork done to my motor was pretty nuts as it got the full treatment from Naprec and then the HKS GTR meisters went to work on it.
Hope that all makes sense fellas!!
FREAKIN AWESOME BUILD! Really appreciate you sharing your photos with us, but i just have one request, are you able to organise them into an order which is closer to the actual build process? Sorry, i dont mean to complain but it seems as if the photos are all over the place. Maybe its just me!
in reference to the quote below, (my quote button doesnt seem to be working)
"The plenumn...they kept stressing about the alloy being to thin and would bulge or deform but once it was on that was thrown out the door. They are quite thinner than Jun plenumn. Also the standard stud mounts were too long and they thought should have been addressed with the plenumn build."
They are absolutely right. I have seen the one on Godzillas drag car and it has bulged/ballooned way out of shape. This may well be because of the amount of boost that is run. not to say that the hypertune is a bad product but i guess thats probably why jun/endless etc charge what they charge.
Keep the pics coming!
Yeah I know what you mean with the pics but the ones I'm posting up are ones taken and sorted by HKS themselves and theres a few hundred of the buggers so trying to put them in some sort of order. I'm posting them up in the order they were given to me.
The main bulk of previous pics were mine and tried to do them in order of the build. When I get time I'll go through them again and see if I can sort them a bit better.
With the plenum, what I was told normal boost up to 2bar is supposed to be no problems at all.
I cant remember exactly how much but Godzillas is way more than that.
power to the garretts!
Cheers for the reply I really do think the jury is out on aftermarket plenums. Interesting info none the less!
Once again, great build, credit to you.
While Quality is up there at least the Jap stuff fits, Eg the Hypertune Plenum above and the High Octane Sump that leaks.
I would be Pissed if I spent 3k on a plenum and it didnt fit straight on.
i agree - i guess not all aust made bits are at the same caliber as jap stuff
Yes, although the design of the hi octane sump is good, it really is very poorly finished. Casting is VERY rough and like you say a lot of them leaked in the beginning. I suppose attention to detail is what makes Japanese products eye candy to us all. Having said that, not all Japanese products are as well developed as some found in the States and here in Oz.
Edited by AtomicBomberMan
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
