How much to get that done?
Same price as all his other OP6 high flows I imagine, around the $1500 mark I think.
A 260kw highflow using OP6 rear end would be the best performance highflow he does using the stock housings.
std high flow would has the best drivability which cost $960 inc GST and braided oil line or use PU high flow that also capable of 300rwkws cost $1400 with a brand new .82 rear housing and actuator.
The 3540 sort of high flow cost $1200 using all stock housings, I didn't like they way how it drives, its very laggy.
  • 1 month later...
Hey everyone.
Got some questions regarding vehicle defects
I recently parted with my hard earned on a 1998 40th anniversary R33.
The previous owner said the car was imported in 2008 and that he bought it 2 months later from a dealer
It has tein adjustable coilovers, which he told me were a defect (i knew that before i bought it) as well as the boost guage located on the drivers side door piller and a Greddy boost controller(Which is now removed).
He then told me that the car was imported in its current state.
This confused me because the car would have had to pass through Regency before it was able to be sold.
WHY did the vehicle pass with clear breaches of the rules and WHY did the dealer then proceed to sell him the "Unroadworthy" vehicle, it makes no sense
I am also hazy on the BOV regulations. Are aftermarket BOV's defectable alltogether or are they legal if the pressure is plumbed back into the system?
Cheers
Slack inspector is basically the only reason it got through, the majority will not pass adjustable coilovers.
It is possible they paid a workshop to comply it and get it registered, workshops will put 100% stock gear in, get it registered then swap all the mods back on.
The latter is much more likely.
I had the same issues with mine, A pillar boost gauge , coilover shocks, dump pipe from dealer , who knew it was defects but didnt care. just wanted the cash. they put all stock gear on it then swapped it over afterwards
mine went thru regency without a buckle on the seatbelt and they didnt catch it. .. safety inspection my ass. I caught it the day I bought it. test drive , no way to secure the belt.the part wasnt there at all.
  • 3 weeks later...
Hi Guys,
Just wanting to know if anybody has had any answers to know if aftermarket turbo's (GT2860-7) will pass through without any hassles on a 33R?
Thanks
At a visual inspection do they look identical to stock turbos? If not then no it will not pass.
Remember they will be looking from above and from below. Do they have tags on them which indicate they aren't factory nissan? if so remove them. Any markings, numbers or letters on the housings may be a give away, grind them off and then grease it up so it doesn't look brand new imo.
Hi Guys,
Thanks
They >should< pass, whether or not they pass without hassle is another thing (depends on the inspector) - you >may< need a document that declares that the 2860 series are a direct bolt on replacement for the OEM turbos (I believe MTQ has these?)
Good luck
-D
I reckon they would get through, they look the same, same size and no modifications to fit. and you can barely even see the turbos. I think if u look hard enough, at one angle with a torch you can make out the word Garrett
Good luck
-D
Thanks for the reply guys, I will give MTQ a call tomorrow and seek a bit more information.
I have it booked in for inspection at Regency on Tuesday so hopefully the car passes without any massive problems.
Once again thanks for the help!
Josh
they aren't going to boost more than your current boost controller so their levels should be the same
but their airflow at the same boost will be greater, hence different load points?
I am assuming they have different trim wheels.
In most cases yes, but that also depends upon the PSI rating of the actuator attached to the turbos
Garret make em in 7, 14 and 21 psi...
All are legal (but never as accurate/safe as an EBC, therein lies the dilemma)
-D
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
