  • 4 weeks later...
f**kwit of the year award @ Welshpool pits in WA (it seems it's not hard to win this award there).
One defect I had was for "HICAS light to operate correctly" on my R34 as the HICAS was replaced with a lock bar and the dash light stayed on.
I obtained permits for the lock bar, and assumed simply removing the bulb will clear the defect.
Apparently not, f**kwit of the year exclaimed they still need to "operate correctly". Can someone please enlighten me how to make a HICAS light operate correctly with no HICAS on the car?
Doubt the HiCAS will work or the light will appear to work with a lock bar in place mate. I would just remove the lock bar, get it through and than put it back on again. If that is what you are planning on doing.
I don't use a lock bar and never had HiCAS issues with mine.
A couple of problems that that idea. Lock bar was on the car when purchased so I do not have a spare hicas. Also you cannot remove lock bar without replacing it with something
Anyway I called up the main office and they agreed it was a shit decision so I can get that defect removed from the list.
FYI (incase you need to clear it in future) you can use a non-hicas subframe instead of the lock-bar solution which is entirely regency friendly.
Good that they removed that defect though - sounded pretty trivial really...
-D
Edit - Krishy, I think you're the only dude I know (aside from me) who still hasn't removed hicas ;)
Hasn't given me any issues since I bought the car, so my theory of why f**k with something that isn't broke yet????
Mine gave me a bit of shit the first year or two I owned it. Narrowed it down to a non-compatible boss kit (Nardi wheel). Got the boss kit and everything started working perfectly.
Was wierd tho - the hicas would get confused after 10-15 minutes of driving and then disable itself (hicas light on continuously) - what was happening is because the magnets in the wheels were in different positions depending on the era of skyline, and it was actually tricking the ecu into thinking that the car has been driving in circles for the last 10-15 minutes.
Also if you went over 80kph within those 10-15 minutes, the rear wheels would change toe (scare the shit out of you too) and you'd have to drive straight with the wheel "not entirely centred"
I screwed around with so many different software solutions too, and none of them were useful - apparently Conzult Z32 can read HICAS codes from the R32 GTR but thats the only one - BUT the software is locked to use only the usb/OBD cable that Conzult sell (so no chance using the software with the cable I bought from the blokes who fitted my nistune).
In the end, the multimeter and the service manual was how I figured it out. And yes, it took a long, long time ;\
That said, working HICAS is great.... taking roundabouts at 60kph like a boss. cos chicks dig it.
-D
  • 3 weeks later...
Hey all last night i got defected for car being low and boost gauge so now i have to go thru regency, was just wondering if anyone with gtst r33 s2 who passed regency can give me some pointers or the list of everything that has been done to clear of the defect. I know about major stuff such as exhaust,suspension but im more interested in HICAS as it was removed before i bought the car (still got it in my shed as i got it with the car) so will i have to connect it properly with oil lines etc. or can i just install it without connecting all the stuff?
-D
still have the HICAS sittin in mine, no problems at all :D
    • Hey crew, Failed my WOF cause of a lower control arm, and I've decided to hit both arms, and also the compression rods at the same time(seems they're gonna be the most likely upcoming failure points from some discussions with the lads over on the G35 reddit). I've looking at these form Z1:  https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-compression-rod-p-40716.html https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-lower-control-arm-p-40674.html I asked Z1 if they'd work as it's the same platform, just RHD vs LHD. I basically got told "Lol dunno". Specifically they aren't aware of any difference but can't guarantee fitment as they haven't done it on a 350GT. So guess I'm asking is if there is any issues with using 2005 G35 coupe suspension parts on a 2005 350GT coupe? Orginally I thought it could be something in the way of the arms that each control arm is designed to be positioned around, but that'd be an engineering nightmare for Nissan needing two different shaped control arms 😅
    • ^ This. The mode door actuator is a common failure, as is the actuator and/or the actual valve for the coolant flow control valve. I also don't know how available the mode door actuator is these days. I've been meaning to look into it and get one from wherever is possible, to keep in the shed for the rainy day when mine eventually fails. Anyway, the advice to you is to search the usual NOS part supply places, or even just go to Nissan and see what they list.
    • Have you got a pic of the actuator? My guess is that unit has failed internally and was flopping around, so the previous engineer who owned it forced it to be fully open to cold air (blocking the heater core path). As far as you can tell, is anything else wrong in the system? Likely you just need a new actuator (not sure how available they are) and then "installation is the reverse of disassembly"
    • I'm happy with the Lsailt unit that I put in, it puts full Android on the top screen so you can run whatever Nav and other Apps you want, while still existing inside the factory functionality like automatic reverse cams, audio input switching, retains factory bluetooth etc. Not cheap and the install was moderate (not simple, not hard) Yours is a V36 not V37 though right?
    • Yeap, all the NC's that I originally looked at that had a hard top were PRHT, which makes the roof line look horrible, hence why I said nope to them My only caveat for another MX5 was it needed to have a hard top, and initially I didn't think you could get a detachable hard top for the NC,  like my NB had Again, a big thanks to Matty for helping me source the detachable hard top for my little girl, they are as rare as hens teeth in Australia, and the few people who have them, keep them Also to Greg, for initially pointing me in the NC direction NC PRHT 🤢🤮 Not mine (I really should take more photos of my car), but a NC with the detachable hard top 😁 To me, the difference in how the detachable hard top roof line looks, and how it actually follows the bodies lines, like they do on NA's and NB's, is chalk and cheese compared to the bulbous looking PRHT
