This is easy to answer, it is illegal to have a venting battery inside the car unless it is vented to the outside.
You either have to buy a battery that has provisions to attach a tube that can vent to the outside of the car, through one of the bungs in the bottom of the spare wheel well.
Or
Buy a fully enclosed battery that does not vent, such as an optima. Carbon34 may know of more batteries you can use.
I believe you can also enclose the battery with a case and have that venting to the outside.
What battery do you currently have?
Just checked the battery out for you, and unfortunately it will not pass.
You will need a AGM or dry cell battery like i mentioned earlier, Optima or Odessy.
Unless it has ventilation holes in it.
I have to second this - the Optima batteries in particular are awesome. I've had the same one for 4 years and it still doesnt miss a beat - even after multiple discharges to zero volts
-D
They are on the slightly expensive side, however they are well worth it.
Unless you like rust i wouldn't recommend anything else, especially after what my century did to the back of my car. Thankfully it cleaned up fine.
Yea a marine battery is similar to what i have mentioned, i am certain all of the Optima Batteries are fully sealed and do not ventilate.
Just change the terminals on the cables that you have so that you can take the regular sized ones instead of the shitty small Japanese ones.
Edited by Grimesy
I'm in the same boat, HICAS hasn't given me any issues so I've left it as is.
If you don't track/drift 90% of the time imo having it is better, nice turning circle and means you can smash roundabouts at 60, providing of course your bushes aren't screwed, then it can feel a bit sloppy.
  • 2 months later...
Im surprised at Regency they dont check for straight through cats considering how many people have them and the fine for not having a cat is huge! All they would need to do is send a flexible cord through the rear exhaust and if it goes straight through the cat...then busted.. Hopefully they dont tho
still no one is stupid to go over the pits with a bashed out stock cat either
what if the brought the car and didnt even know about it. Thats what im saying i dont even think regency check it which youd think they would
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
