Has it got the sequential box back in it?
RH9? There's enough power to run a 7 :thumbsup:
What box is in it, Paul? And will it be running in the fastest street car comp at WSID next month? :D
i asked that question 5 pages ago :)
Edited by TiTAN
  • Replies 126
Posted Images
Went down to JEM last night, and found out they used Adams Mainline for the AutoSalon.
What was it that gave it away? The big JEM stickers on the dyno or the big ones on the control unit in all the photos and video from the event?
(Apologies if you didn't attend the event - it just read like you had been super-sleuthing.) :(
LOL!
First of all i would like to say well done to all involved 1250hp is very impresive.
What would be the cost involved in building a engine like this complete with turbos etc?
1 very hot wife,
1 small child
Left arm
Right leg
And a patridge in a pear tree!
$60k would do it I should think. How many would you like?
60k thats a bargain to make an extra 200hp atw compared to when it had the crd 2.7 in it.
since the 2.7 is tired and no longer of use i would be interested in purchasing it so please if its for sale shoot me a pm
thanx Paul
probably due to the fact it mite be running some 15" drag rims and a parachute now? :banana:
So when is this bad boy going to hit the strip? And on that topic, why on earth has GAS2JZ not hit the 1/4 mile either? That would be fricken cool to see :angry:
rh9 will be hitting the track in jan 09 with drag radials...
it will not be running the nitrous for the drags.. and about 1000hp at the wheels...
we will seee if the gearbox is up to the job...ha ha..
cheers, mark
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
