this is pretty cool:
http://www.tomshardware.com/reviews/geforce-gtx-750-ti-review,3750.html
apparently runs quite well. Cheap SLI option if they release another one with more memory and wouldnt need nearly as much power..
  • 3 months later...
Custom Desktop:
Case: Cooler Master High Air Flow 932 Black Chassis
Motherboard: GIGABYTE GA-Z87X-UD5H LGA1150
CPU & CPU Cooler:
Intel Quad Core i7 4770K @ 4.2Ghz, w/ Noctua NH-U12S
RAM: Corsair Dominator Platinum 16GB 1600Mhz DDR3
Monitor: Samsung 27" S27A950D Series 9 120Hz 3D LED Monitor
Graphics Card: 2x Sapphire AMD Radeon HD 7970 GHz 3GB CrossFireX
HDD(s): Kingston HyperX 120GB, Samsung 840 Evo 250GB, SanDisk Extreme 240GB, Western Digital WDC 1TB HDD
OS Used: Windows 7 Ultimate x64
Sound Card: Creative Audio Sound Blaster ZxR
PSU: Corsair RM-1000 80 Plus Gold 1000W
Peripherals:
Keyboard: Logitech G710+ Mechanical Gaming
Mouse: Logitech G9X Wired Gaming
Mouse Pad: SteelSeries 9HD Pro Gaming
Headphones: Audio-Technica ATH-A900X
Speakers: Audioengine A5+ 2.0 Powered System
Microphone: Zalman Clip-On ZM-MIC 1
Router: NETGEAR D6300 WiFi Modem
please add me on these services if you play these games!!!
Steam: flano87 (Call Of Duty: Ghosts)
Origin: Flano_Z87X (Battlefield 4) HC servers (eGL, CYN8, mad BF, games.on.net)
Edited by flano87
i've gone through 4x WD greens ((WD20EADS). never again. currently moving over to the seagate SV35's
uh, can i change that to 5 with the 6th one within the next few months? lost my FTP drive on the weekend (so pissed), and theres a problem with the sector cound on the other one.
ugh, worst decision ever getting greens back in the day. another 2x SV35's comming up
Edited by liger
  • 1 month later...
  • 2 months later...
Coolermaster Elite 110 case
Intel i5 4590 CPU
Asus Z97I-PLUS m-ITX motherboard
2x 4GB G.Skill DDR3 RAM
120GB Samsung SSD 840 EVO
1TB Western Digital Black 3.5" HDD
MSi GTX 760 OC ITX video card
Corsair CS550M semi-modular PSU
Corsair H90 liquid CPU cooler
It was a tight squeeze to get everything in there, but was fun to build (and take apart). Planning required!
Pre H90:
H90 fitted. The 140mm fan unfortunately can't be used here, fouls wherever you put it. The standard 120mm front fan was flipped so it pulled air from the radiator and out the front.
For the google searches: Yes, 140mm liquid cooler radiator does fit inside the Elite 110 case, but the 140mm fan can't be used. Also, a good mini ITX video card is the MSi GTX 760 OC ITX, it's compact and much smaller than it should be hahaha.
  • 3 weeks later...
Update, threw a CoolerMaster Seidon 120V in, it fits fine with the 120mm included fan.
So... 140mm fan hits the RAM sticks, should be able to use the 120mm fan though. OR, you can buy/install 120mm radiator, works fine!
Max CPU temps dropped 10°C, so airflow obviously is better!
tl;dr - use a 120mm liquid CPU cooler in the Elite 110 case.
Recently upgraded a few components, loving this gaming beast!!
Custom Desktop:
GIGABYTE Z87X-UD5H LGA1150 Motherboard
Intel Quad Core i7 4770K @ 4.5GHz CPU
Noctua NH-U12S Heatsink / PWM CPU Fan
Corsair Dominator Platinum 32GB 1600MHz RAM
Sapphire AMD Radeon R9 290X Tri-X OC 4GB GPU
Kingston SSDNow 128GB Solid State Drive
Samsung 840 Evo 250GB Solid State Drive
SanDisk Extreme 240GB Solid State Drive
Western Digital WDC 1.0TB Hard Drive
Creative Sound Blaster ZxR Sound Card
Corsair RM-1000 80+ Gold Power Supply
Cooler Master HAF 932 Full Tower Case
Peripherals:
ASUS VE278Q 60Hz LED Monitor
Samsung S27A950D 120Hz LED Monitor
Audio-Technica AT9903 Clip-On Microphone
Audio-Technica ATH-A2000X Headphones
Audioengine A5+ 2.0 Powered Speakers
Audioengine AS8 Powered Subwoofer
SteelSeries 9HD Pro Gaming Mouse Mat
Logitech G502 Proteus Core Mouse
Logitech G710+ Mechanical Keyboard
NETGEAR WiFi Modem / Router
My old Geforce 570GTX kicked the bucket earlier on this week so I replaced it with a Gigabyte 970GTX G1 edition, while I was at it, I gave the CPU HSF a much needed clean (haven't really touched it in over 3 years).
Besides a decent boost in gaming performance I noticed this card uses less power at idle compared to the old 570, my UPS is showing ~100W for the system vs the old 180W.
Still haven't bothered to OC my i7-2600K yet, haven't really found any program I use to really stress it out even at stock clock speeds.
Thinking of getting a much needed monitor upgrade (still running 2 ancient 16:10 samsung business mointors), thinking of getting a AOC 24" 144Hz G-sync monitor so I could use the feature from the new graphics card, but would running it triple screen setup with the two old 60Hz monitors cause issues?
Edited by Mayuri Krab
Wouldn't it look weird with two old screens and one new one?
Another update on my box, moved the SSD from the side to the top (next to the 3.5" spinner), had to re-wire the case hahaha.
Also flipped the two 120mmm fans on the radiator so it blows air out the front of the case (i.e. reversed). Temps dropped 5-10 degrees celsius :D.
The 2 old screens would only be used for multi-tasking and extending the desktop screen to drop my random bunch of shortcut icons, while gaming/movies are handled by the new screen.
Ideally would love to run 2 (or 3) 144Hz screens but budget won't allow.
Also how are you guys getting such neat cabling, my PC's inside just looks like a nuke explosion of cables, which probably doesn't help with the fact that my PSU isn't modular.
looking at building a new rig in January and weighing up what i plan to get...
ive been putting up with my heavy-ass desktop for a while now so been thinking about going Micro ATX. specifically this: http://www.scorptec.com.au/product/Cases/Micro_ATX/53625-FD-CA-ARC-Mini-R2-BL-W
the problem is finding the right motherboard. not really fussed on processor because my original series i7 still never breaks a sweat, but concerned that all my shit isnt going to fit. currently have a radeon R9 280 gfx card, a PCI sound card, 2 SSD's and 2 HDD's. That plus SATA blu-ray drive, and 750+W power supply. Reckon its worth the hassle of just go next size up case?
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
