  • 4 months later...
did anyone try to change ta another brand? and did that help?
i have the same problem, had a bunch of other brands before then after one change it started to spit out of the breather.
Yes and yes. You can change the oil or extend the breather as above.
  • 1 year later...
Let me revive this thread.
I've been having this issue with my rb25. Oil leaking out of my tranny breather hose. Yesterday I changed my fluid, thinking that maybe my shockproof lightweight had worn out and become even thinner and this would fix it. I also added a small water/oil separator at the end of the hose in the engine bay, like someone in this thread suggested a long time ago. I though this would fix it and it would take forever to fill the separator/filter. Well, today I popped the hood to check on my filter, and...
So, after doing further research I came across this thread from '10.
https://aus300zx.com/xenforo/index.php?threads/oil-from-gearbox-vent.300868/
Very interesting. One member mentions how having a bent vent tube pointing downwards can cause this problem. I did noticed mine is bent a bit, downwards. I will bend it up a bit as soon as I get a chance, hopefully this solves my problem.
I just thought I'd share this in case anyone out there is having this problem.
I will report the results.
I still have dramas with mine, Thinking about changing oils and going away from redline lightweight, But the box feels so much nicer with redline oil in it.
I'm fairly certain I bent the tube straight a while ago and still didn't fix the issue, thats when I went to the breather setup, but I'm getting problems like yours. Was starting to think I had put the one way baffle plate in the wrong way when I rebuilt the box but think I would have bigger issues if that was the case.
Be interested to see where everyone else is at with this issue, I first thought someone mentioned a batch of lightweight shockproof that was doing this but it was not an issue with later batches but I've had a few bottles through mine by now
Mine worked a couple of years with redlige. But after one change the problems came. Changed again to a nej redline and the problem remained. Now i drive with mobil1 and havent had a single problem ?? First i bought a cheaper oil and drove a couple of miles then changed to the mobil1 just to clean the inside and get rid of the redline oil
Edited by Ajfa
Mine worked a couple of years with redlige. But after one change the problems came. Changed again to a nej redline and the problem remained. Now i drive with mobil1 and havent had a single problem [emoji1303] First i bought a cheaper oil and drove a couple of miles then changed to the mobil1 just to clean the inside and get rid of the redline oil
Which oil are you using? Im thinking of changing
A Guy here in sweden works with renovate skyline engines and gearboxes. He hates the redline oil and says it damages the gearboxes. The picture is of the redline oil
the other picture is the oil he recomended and the one i have.
Redline shockproof is a band aid for stuffed synchros, not for tracking. Or so I've read.
Depends on the viscosity, lightweight is intended for old boxes that are still ok, heavy is more for stuffed synchros and such. Or so I've read.
  • 5 weeks later...
Well, it's been over a month now since I bent my vent tube up slightly, and still having the same issue. As much as I love this blue stuff, I might have to go a different route... I was also thinking maybe the baffles inside the tranny.
I'll look into that mobile mobilubeGX. Any other recommendations?
Edited by andres14oj
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
