I though it was about time i put something up here about my car.
It started out as a standard GTS4 with only a cat back zorst imported a few month before i brought it in early 2005. first mods were front mount and a set of chrome 18's
I drove around with the car like this for a year or so with no other major mods just a dump pipe, front pipe and a bleed valve pushing out about 160rwkw.
In early 2007 i noticed that my car started to idle lumpy, did a comp test on the motor and found that i had nothing in piston 6. So i decided to go all out and chuck in a Rb26. this is the piston from the rb20
I managed to find a R33 rb26 with 80,000k's with gearbox from Japanese motorsport, i also got some coilovers, strut braces, stainless front pipes and 32 gtr brakes. I also got a Power-FC D-Jectro all installed by Tilbrook Auto & Dyno, the car was tuned by Martin Donnon and made 230rwkw.
Not long after that i got my new plates and earlyer this year i brought a set of 18x8 1/2" Drift teks.
I have now upgraded to R34 GTR rims painted the same gold as the Drift teks and i also brought a GTR interior.
I have now also fitted a GTR bonnet and grill. My next major mods are a set of Garett GT2860-5's, HKS dumps, Nismo pump and Sard 700cc injectors which i hope to have installed in the next week or 2, when there on and tuned i'll post of the dyno sheet, it should be around the 300rwkw mark :cheers:
Edited by DSTROY
https://www.sau.com.au/forums/topic/250585-r32-gts4-with-rb26/
  • Replies 46
Amazing work!! love the engine colour, did you choose that or did it come with it?
I painted it myself before it went in, its just spay can stuff with a clear coat, colour is Cyan Metalic you can get if from Super Cheap.
Damn this thing is awesome, a Sleeper and a half!
You couldn't even tell, unless you can recognise the exhaust note and you probley freak the crap out off ppl trying to drag you off at the light.
BTW you said you have an APexi Power-FC D-Jectro installed, but I see you still got the air flow metres in one of the pics... I thought you did not need air flow metres with the D-Jectro..?
is your gtr bonnet Black as well? looks gunmetal to me
Yeah it is Gunmetal, will get it painted when i get some other bits and pieces done, just dont have the funds atm.
Make sure to post up your dyno result in the forced induction sticky, i'd like to compare against mine as we are using almost exactly the same parts.. 'cept for the d'jetro.
will do mate.
The air flow meters are there to keep the street legal look, but they have had all there insides removed to increase flow.
Here's the dyno graph :)
This is my latest mod to the car, cold air box. Helps keep the hot air out and it also hides my boost controller solenoid :P
I also went out and brought this little kit the other day, just need to find the time to put it on.
  • 3 weeks later...
so.. where does the air go? I can't see any venting to allow flow through so does that mean that it will just be a dead pocket of air around the cooler or am I missing something? Other than that it looks very nice, trying to figure out where and how to mount one in my car.
I have got hold of a R33 front left inner guard that i will cut the vent out of and rivet it behind my cooler :domokun: i just ran out of time.
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
