hey guys recently perchased my r33 an was wondering what i can do to get a little more hp out of the stock engine b4 i have to start spending $ on bolt ons.
It already has a hks s/steel dump, front mount and gfb dual port bov.
Heard the series 2 has ceramic wheel turbo an isnt a good idea to wind the boost up past 10psi is this true?
Others say the s2 has steel wheel any info on wot i can and cant do would be greatly appreciated as i've only played round wif 2jzgte's b4 hand an pretty much done away wif stock turbo's streight away.
thanks Matt
https://www.sau.com.au/forums/topic/250924-stock-r33-series-2-turbo/
10 psi max with an EBC would be the best bet... anything over that and you'll need an aftermarket ECU to prevent R&R
also ditch the bov, the stock one is fine and legal... mine holds 20psi all day every day
with a PFC and a decent tune i ran my stock turbo @ 1 bar for 12 months but it is generally accepted that 12psi is the limit of the exhaust wheel
ALL recent skyline turbos (R32 onwards) have a ceramic turbine wheel.
R32 has a steel compressor wheel
R33 series 1 has a steel compressor wheel
R33 seres 2 has a nylon compressor wheel
R34 has a nylon compressor wheel
AFAIK.
had 3 stock 25 turbos over 1 bar now and never killed one, current one (s1) whines hell bad but still boosts fine and holds 15psi
for your 3 , I will raise you well over 30 popped ones on R33's who thought it a good idea to run 1 bar based on shoddy advice.
give it 1 bar of boost often enough and they let go. I am very confident I could pop each and every one of those 3 you have had on an Rb25 within a day , given a go at them ;)
The sheer number of popped R33 turbos in the history of this forum boggles the mind. And if I had a dollar for every guy who said they ran 1 bar for a year with no troubles only to have the turbo pop within the month I would also have a few bucks in the pocket. :D
1 bar on an RB25 with ceramic wheel stock turbo = hand grenade.
+1
BUUUUT...
i thrashed the shit out of mine aswell... limiter abuse galore and spiked out to 1.1 bar pretty often (turbosmart mbc ftl)
damn thing had NO shaft play when i pulled it out...
i dont reccomend people doing it though... not to mention it really doesn't make any more worthwile power over 12 psi anyway
depends if you're running a bleed valve or EBC too. on my R31 I ran a bleed valve and it hit 15psi in the midrange and tapered off to 10psi at high revs. That (standard) turbo had no problems at all, most likely because your peak shaft speed is at redline (assuming same boost level at all revs). The turbo doesn't have to work too hard to produce 15psi at 4000RPM and then at 7000RPM it's only producing 10 pound.
EBC running 1 bar to redline, different story. Then the turbo is forced to spin much faster -> fail.
AFAIK.
Exchange steel for aluminium, i dont think there has ever been a turbo with a steel comp wheel.
so its safe to run say 10psi without doin any harm? the engine only has 90,000k's on it an i dont have alot of cash atm so a lil more boost wont hurt for the time being hopefully, if i was to run 10psi all day every day how long till the wear an tear takes its toll if it even does? i'll most likely pull the t/smart boost tee off my 2jz an wind the boost in 2morrow, iz there anything else i should know about, to watch out for or what will be needed to run aswell to keep things safe?
also around what hp roughly will 10psi get me?
thanks for the info guys its greatly appreciated, Matt.
Edited by MAFIA R33
I ran anywhere between 10-12psi for just over a year and when i pulled the turbo off it was in excellent condish still. Mind you the car was running standard boost before that with only a cat back zorst (which got boring quite quick).Have a look at the RB25 upgrade thread that should give you a good idea of what your car should be producing. My car for instance with Blitz FMIC Turbo back zorst, EBC made 188rwkw @ 11psi.
10psi won't wear anything out any quicker especially if you treat your car nicely ie warm it up before boosting and drive gently the last few minutes of your trip to let everything cool down again. keep it serviced regularly and it'll be sweet.
you should keep an ear out for pinging on the new boost setting, with standard exhaust my series 2 will ping more so I've left it standard until i do the exhaust.
12psi
stand alone ecu with aggressive tune
good tyres
pineapple, camber, castor kit
short shift kit
intercooler
good 3" turbo back exhaust
cold air intake
there wont be much on the street that can beat you in this setup
should make around 190-200rwkw
omg.. here we go again..
I rev bashed my RB20DET with a RB25DET S1 turbo for 2 years @ 1bar, turbo still fine... the new owner bashes rev limiter more than I do, still fine.
Did it hold 1 bar to redline? With a bleeder it probably didn't.
As mentioned before for your one Rb25 turbo I can name plenty more than 30 dead ones.
Ohhh the stupidity. First you start with the "omg....here we go again.... " line as if you know what you're talking about. Then present a post with 2 basic and compounding flaws.
Flaw 1: You are using anecdotal evidence from 1 car. (Whereas plenty of people have had turbos lose their exhaust wheel running 1bar)
Flaw 2: You were using an RB25 turbo at 15psi on a 2.0L engine !!! (This is NOT THE SAME ABUSE as running 15psi on a 2.5L engine. The shaft speed of that turbo on a 2L in not as high as if it was running the same boost on a 2.5L engine)
So yeah, other readers please disregard his post. I have no experience personally with blowing an RB25 turbo. I run 10.5psi (as on my gauge) - no issues after 3 years.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
