I left the factory restrictors in since I am already robbing oil for the VCT.
Drilled the oil returns too.
WIll post up how it goes.
Same setup as me, the factory ones are supposted to be 1.8mm. How is it working out for you so far? im tossing up whether to fit a large capacity sump to prevent any oil starvation in the bottom end just as some extra precaution...
With the solid lifter conversion I no longer have to feed the vct orthe hydraulic lifters, I am going with onw only head feed as the 26 guys do ans restricting it to one mil.
Farken sick of too much oil upstairs. :P
just finished doing this tonight. couldnt get enough bite to pull it out without drilling and tapping it a fair way through, but i simply loctited the bolt i used in there and am going to cut it off flush with the front. due to tapping it so far and not having a long enough 1.5mm drillbit i had to put the hole in the side a bit further back, but i had a good look inside the head and i cant see it making any difference.
anyone done anything special to make sure the plug doesnt come out? its pretty tight but i wanna make sure its not gonna move.
Loctite I guess. I doubt it will come out though. There isn't enough pressure or surface area to cause it to push out.
I will post up how I go too. Interested to see if I have too much oil in my head or not.
  • 5 weeks later...
Sorry guys I know this is slightly off topic, but I didn't want to start a new topic. I am currently putting a rb25 vvt head on a 30 and will be doing this mod.. but there is a oil return on the exhaust side of the head that goes via a pipe to the block. So my problem is RB30 blocks don't have this hole in the same place, so would it be alright to extend that hose and use a t piece to let it return through the turbo oil return on the block. Hope this makes sense I can take pictures if needed.
  • 1 month later...
The guide is just so vague with everything. I mean it helps a fair bit with what fits what and so on, but when it comes to the finer things it sort of tells you how to get it done but not really. If I really want to learn how to do this I want to get experiences from others and how they went about it. I mean the guide still says NEO heads may have different oil and water galleries and hasn't been updated so how can I rely on that when going down this path.
If there is any more detailed information available could someone please post a link. Thanks
  • 3 weeks later...
drilled from one feed to the other .. get the angle right or you could end up with oil where you dont want it
picky of where I drilled between the first 2 (intake) cam journals
Drilled and tapped the outer layer to take a bung
Dummy fitted the bung to show what it looks like finished
Head was then dissassembled for further mods before being cleaned an reassembled
Hope this helps people
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
