The rear wheels are not in a slip event if the dyno allows the front wheels to match speed... Even for a split second :)
there are a few other factors that govern GTR all wheel drive though. not just wheel speed difference between front and rear. but consider that the wheels are driving the dyno not the other way round so yes as you start the car rolling teh rears are moving but the fronts aren't, the ecu then tells the transfer case to pressurise and torque is transferred to the front. anyway, most awd dynos can give you a reading for the front and rear.
Yeah it's not the end of the world either way!
R32's are good because you can flick the switch :)
Yeah but if you truly lose <10kw why would you do it?
skidz? :happy:
Only time I've pulled fuse was driving home with a broken front drive shaft. (Mounts) - Mind you, it DID take me a few months to fix it.. :thumbsup:
Edited by GTRPowa
is it possible that the computer takes power out when its running in rwd ? then puts bak in when awd ?
if u run the car in awd then rwd on the same dyno and the result is the same, that means the dyno is equalling it out bcos it knows whats happening ? where as if u ran the car on an awd dyno then went around the corner to somewhere else and ran it in rwd it would be totally different ? and yes i know different dynos show differently.
Bloody hell don't start the fixed vs percentage debate again. There like a 10 page thread on it.
Percentage loss is a good way to work out factory approximate drivetrain losses. When you start making 3, 4 or even 5 times the factory power levels, those percentages are not logical any more. There was a big thing on it here, once again, a lot of people agreeing to disagree.
My arguement is you can't say that a drag car making 3000hp at the wheels is still going to have a 20% drivetrain loss coz that's BS
The most accurate models I've seen based on lots of data use a percentage loss + a fixed component, but even then it is only accurate for a certain range because as you said, you cant be making 3000hp and expect 20% drivetrain loss.
Like a lot of models they are only accurate in a small range.
Edited by Rolls
nah it's no where near that much. 400rwkw is about 375-380awkw or so. if you've got 301awkw you would be about 320-325rwkw on most dynos. there is not much difference between AWKW and RWKW on dyno dynamics dynos. certainly not 15%. and it's not a fixxed percentage anywway. the gap does widen a little bit the higher the power level but it's not linear. like it might be 20kw difference at 200kw and only 25kw at 400kw. there is no fixed answer. regardless of that even just different dynos vary a bit even when all reading RWKW or AWKW.
I got 294awkw and 307rwkw (R32 GTR). So, pretty close!
all depends the condition of the transfer case... but on standard transfer cases its 10kw difference max... a modded transfer case can increase the awkw > rwkw difference... but on some older 32's with worn cases there is zero difference
anything more than 10-20kw is an exaggeration IMHO
agree on both points. yes it's not the end of the world, and yes flipping the AWD/2WD switch is fun. :)
no it the ecu doesn't 'remove' power when you put the system into RWD. it just sends all the power the engine makes to the rear wheels. the reason you get a little less power when the car is in AWD is that there is a parasitic power loss in the transfer case, front shaft and front diff. it's not much though and certainly not 50kw on a car making 400kw.
no it makes no difference. an AWD dyno dynamics dynamometer is basically 2 "2WD" units together. so you can run it in awd using both sets of rollers, and then simply run it in RWD using only the rear set (with the car in RWD mode). The dyno doesn't "know" what you're doing. it's exactly the same as "going around the corner to a RWD dyno". they operate exactly the same way.
yeah that's more like it. very typical result for a GTR at that power level for AWD vs RWD. god if it were 50kw as some people claim imagine how fast the car would feel when you switched to 2WD mode! you'd suddenly be free of the 50kw drivetrain power loss and your car would be a rocket ship. that's the easiest way to tell. any GTR I've run on the road between AWD and RWD you can tell it accelerates (when rolling) a little better in RWD (providing you have traction at that power level), just enough that you can notice something, but not a huge difference. which again backs up the evidence that's it's a handful of kw's at most 'normal' power levels.
haha very funny :)
mine does that off idle
That is the dream.
Who knows when you're going to need to rip a burn out and when that time comes, do you really want to be wasting precious smoky seconds with things like 'spooling the engine up' and 'clutch dumping'
Didn't think so.
I'll throw up my little 2 cents with this 4WD vs RWD garbage.
On unigroups dyno a few years ago I made 370 RWKW.
One week later I made 361 AWKW on Rigoli's dyno at a Dyno day.
I realise they are different dynos's and stuff but they are my results.
if i could judge the difference between rwd & awd that would be good - rwd mode is stupid though, 3rd gear has no traction what so ever
yeah I know that's a problem when you have 400kw! try getting on it hard in 4th gear it should have plenty traction in RWD at those speeds, then try in AWD. you will find it feels a bit quicker in RWD but it's not a huge amount. if it were really 50kw I would say find some stickier rear tyres, cut off the transfer case and enjoy the cheapest 50kw we will ever make! :)
WELL WHEN MINE WAS TUNED IT WAS 375AWKW. dyno comp did 376rwkw.. so f**k all. bear in mind that the skyline has a locked center when on a dyno.. if the transfer was slipping i would expect to see a differance.. not a viscous coupling sapping power.
Further reading on trash forums, I found a bright spark with a convincing way of saying the drive train losses are fixed, what with all the articles/forum threads around talking about percentage losses.
Eg: You might make 200kw at the engine, and 140kw at the wheels. Then if you make 400kw at the engine, you'll make around 340kw at the wheels. Excuse the fact some of you probably know this, but I'd assume lots of people (myself included) think about fixed percentages.
And if that's the case, then the AWD mode on GTR's would used a fixed amount, instead of a percentage too. The pieces come together! :D
Edit: Excuse the fact if it's posted somewhere here, but I haven't seen it, and in fact, I've never read it this way until today... And I read forums a bit too..
So a 100kw car makes -60awkw???
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
