Even @ 330rwkw on E85/.63 - that is pushing then limits of believable. But at least its almost believable rather than outright fudge.
Maybe low 20's its believable (330rwkw that is). A 3582 .82 wouldn't make that much "claimed power" at those boost levels on E85.
you know trent from status uses the same dyno... with the same calibrations, and has had similar results on customers cars with a similar turbo set up?
everyones quick to jump on the dyno debate. If we had a drag strip in SA i would seriously consider it... with previous tune of 360 rwkw's i managed a 1:18 flay around mallala in a drift car on street tyres. this was beating 330 rwkw gtr's that were done on a mainline dyno (willall) so clearly some of you need to pull your heads out of your arseholes and face reality that such results possible.
ever think that maybe mainlines read low? I had an RB20 r32 ages ago with a 25 turbo on it with an EEPROM chip remapped. made 148 rwkw on a mainline.. where as on a roller dyno (DD) it made 180 rwkw.. and on the AMM hub dyno made 185 rwkw with the same correction metiod.
19psi though mate...
5557 .63 made that same power (roughly) on >30psi of boost. Albeit on a 2L SR engine, it's still something. Why do SO MANY people make around the 300rwkw mark on 1psi less? Surely there isn't 90kw difference in reading between the dynos....
Just know that it's all about how much you enjoy the car, and how well it performs - a dyno is simply a number, and doesn't mean ANYTHING in some cases. This is one of those cases...
the whole point is that a 3076 cant push enough air to make 400rwkw.
and its very misleading to forum users that think they can go out and get a 3076 and make 400rwkw its just not goint to happen. its a 300rwkw turbo with E85 you can get 340-350rwkw out of them thats about it.
yes your correct becuase thats exactly what it did.....
the car in question was initially tuned on this dyno by amm using those exact corrections so i gave simon that graph today purely as a direct comparison to how it was before. the result be a 40odd kw increase over the previous setup. i had no real choice there.
i did todays whole retune using more "roller correct" corrections and in actual fact it produced 357kw. i dont think that turbo is gonna do too much more and i had no interest in trying. the result was great as it was.
at the end of the day, its a tuning aid and a VERY good one! the 397 was merely a reperesentation of todays gain.
I don't know what dyno it was on, but I remember recently someone pushing around the 400rwkw mark from a 3076 of some kind, but on a ridiculous boost level around 30psi - WELL out of efficiency
i bet they'd find that if they dropped the boost and tuned it accordingly, the loss would not be dramatic.:thumbsup:
I must have the wrong thread here I thought it was the 400rwkw thread, not the 390rwkw thread. Can anyone link me please? :whistling:
Lol, so true.
Im pretty sure the dyno blew up when he recorded a power level of over 9000
Edited by Nee-san
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
