I must be missing something, whats the relevance to this discussion Marko?
I am making a statement that its a nice car, is that not allowed on sau?
about the same relevance as that 300,000 word 20 year old sig quote
hmmmm...i will amend my sig if its that much of an eyesore
Thought that may be the case!
enough with the bait! give it a rest
Always a bit sceptical when theres no corrections on a dyno dynamics graph for all we know that graph could be stock turbos with 200 degrees of intake compensation.. Before xmas my car made 492rwkw on e85 and 26psi on a pretty hot day with 28degrees AirTemp 49 degrees InletTemp compensation worked in the figure i thought nice not much to go till 500 now. After having a few problems we stopped tuning for the day, 2 days later went to another dyno, tune unchanged made 460rwkw i was like :mad:
Anyway dynos tell porkies we need more mph on the 1/4 in this thread.. :cheers:
There was a full thread on the car specs if you want to know more - rb29 was in the title IIRC.
"RB29 wow". Great thread, and that graph is pure car porn.
Hey question for you guys.. Im currently building my engine, and a thought crossed my mind.. The gtx3076r's compressor map shows it can flow around 65lbs/min of air at ~29psi. Could this translate into a hopeful ~530 - 550rwhp? Or ~400rwkw? I mean, could it be done for sake of argument..
The housing configuration i figured would be a 1.06 T4, most likely divided and mated to a twin scroll manifold.
Any thoughts guys? :)
I wouldn't, not unless you've seen anyone push one that hard and make that much power on a dyno type that gives results which reads in the area you aim to reach that power on. You certainly won't be getting that power from one on pump gas on any dyno, E85 or something similar would be a must.
400kw should be achieveable on E85 with a GTX3076R at least on a hub dyno, actually even potentially with a run of the mill GT3076R.
I thought the same thing, the GTX3076 compressor flows nearly 5 lbs more than the GT35 on paper so 400atw should be theoretically possible with enough boost.
Was definately thinking the e85 route aswell. IIRC, some of the supra guys have them running 26psi, so i figure the odd jump to 29psi would be ok. And because of the 1.06a/r, EGT temps *should* be fairly acceptable.. I think?
Wouldnt the gt3076 be out of its ideal efficiency? I mean, i havent seen one go past ~24psi, but then again i havent looked for that exact figure..
My build should be done around september, so might push it to 29psi to see if its achievable.. For science-sake :)
Scotty, glad to see im not the only one! :D i know the gtx are marginally slower coming onto boost, but i figure the divided housing mated to a twin scroll mani should bring it back to bee's dick of difference.
Thanks for the input gents! :D
The normal GT3076Rs have been pushed up past that before and made good power, but yeah they are definitely pushing shxt up a hill. I reckon the gun choice for what you're looking at doing would be a FP GT3076RHTA personally.... have a look into those while you're considering it.
They are claimed as 59lb/min, which sounds underwhelming compared to the GTX but bare in mind the maximum flow is rated to whatever flow efficiency the company decide to use as a cut-off and isn't an absolute - and also Garrett themselves have ultimately said the 77mm compressor used on the GTX3076R isn't suited to the GT30 hotside by putting it on the GTX3576R, the extra flow is argueably redundant on the GT30 turbine.
I think the HTA76 wheel is basically the ultimate compressor for a GT30 turbine, the most flow you could put through that turbine with better response than a normal 56trim GT3076R wheel.
Problem with ramming so much boost etc, what happens if you get a slightly average batch of fuel?
There is really not enough room for error running uncontrolled fuels in street cars.
Mine is lasting well so far, haven't had any bad batches of Caltex yet either according to the wideband anyway. I did hear it pinking once on cruise one of the hot days we had, but its running 18:1 there for economy atm. >_<
Im not scared about the little VQ, seen many stock VQ30det's pushing big numbers (400-450kw) and the VQ25det runs the same rods, the main worry is the auto. Either way, I have spare engines and a trans here.
I doubt 400 is attainable with the auto, (I would be happy with 350) but a built RB with a GTX3076 would sh*t it in. I will check out the HTA76 further Lithium but I think the compressor housing is a little too big. Does it still run the Garrett rear?
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
