Yes, both gervaise and I had our box's cryo treated at Dans insistence.
both car make over 400 kw's and both get dragged and circuit driven and have done for 3 years with zero gearbox issues.
Does it work, How do you prove it. You can only disprove it by breaking the box and that has not happenned to date so I'm going with a resounding yes! It does work.
Hey Noel,
Those two cars are the "For" argument that I have heard, what did it cost and what state does the box have to be in for the process ?
Cryo treatment is relatively inexpensive Mitch, somewhere around the 300 dllar mark for the complete internals from memory.
The expensive bit is obviously stripping and rebuilding the box along with new bearings and sychros as common sense would dictate.
Cheers XKLABA & NXTIME, I take it this would be them ..btw how were they for price and service ?
Company
Ace Cryogenic
Address
Barrington Road
Silverdale NSW 2752
Phone
02 4774 0256
Edited by ezy_09s
Small thing, but I don't think cryo increases strength (technically). It works by improving the weak points by ensuring more uniform grain structures. Well at least that was my memory of it from 10yrs ago when I once read about it
I'm not a metallurgist, but according to the experts at the company that perform the treatment, it strengthens the metal by 300-400%.
The only reason why a metal like this is potentially weak is because of the grain. Improving that grain structure of the metal at a base level certainly does make it stronger.
Standard gear RB20 gearbox - 640hp at the wheels
Standard gear RB20 gearbox - 380hp at the wheels in a drift car thrashed every week for 4 years and still going
R33 GTST, GTR gearboxes all making over 500hp at the wheels, 9k rpm launches on semi slicks, flat shifting, clutch dumping/kicking and general abuse
Have never broken a single one....ever
OK I have finally made it to the 400 kw thread.
Car running rb26 block and -5's
Car made on 19psi 420rwks - I'm wrapped :D
Massive thanks to Trent & Cat from Chequered tuning who tuned the car over the weekend (wouldn't go anywhere else)
Trent tuned a felxi fuel set up on my Autronic
Also a huge thanks to Tas (Power Glide GTR) for getting the car to where it is - car has turned out mint mate :)
Is cryogenics recognised or practiced by the Japanese?
I remember when I first joined this forum and reading up on this when paul diemar was using cryogenics as well as crd...it obviously is tried and proven, however, it also seems to be a thing of the past OR ppl simply dont discuss it these days.
I've always been interested in this subject and TBH if I built another engine or box, I would use this method
I have had the luxury of back to back testing :)
R32 GTR making 600hp at the wheels
Blew 3rd gear
rebuilt without cryo
Blew 3rd gear
rebuilt with cryo
still going 12 months later, same abuse
Technically it's hardness roy, which can come at the expense of strength or "toughness" also there is the question of penetration and how deep you can reach into the grain structure.
That's sort of my concern.
Blew 3rd gear
Blew 3rd gear
rebuilt with cryo
Wow, those results are quite something ..im assuming thats just using the factory gearsets in all these boxes ?
Ah apparently not .
Its just a more uniform & consistent hardness across the part.
http://www.nitrofreeze.com/cryogenic_treatment_for_motorsports.html
Ah apparently not .
http://www.nitrofree...otorsports.html
That article doesn't make any reference to the depth of penetration of the process, which was my main concern.
Further, while it is true that it can relieve internal stresses and reduce voids and dislocation in the grain structure.
All of the effects such as increased wear resistance, point to more carbon being brought to the surface and the formation of a harder outer case (Case hardening) which I would have though would come at the dentriment of toughness when you're talking about the gearset globally ?
Not against the idea at all just need to know that it will work the way I need to to.
TL;DR basically. Lol.
One of my mates just started a new job with a company that does this cryo stuff. Since I plan to do my brakes soon, I'll ask him how much to do the rotors. Might make that skim job last a bit longer, after that they are for the dust bin,
Can you confirm that boost figure please.
Proof is in the pudding. But still dubious of the 300-400% claim. Can someone point me in the direction of a good article on this?
My understanding from the old Iron Carbon diagram has always been strength-Ductility-toughness vs hardness is greatly dependent on the rates of heating and cooling etc and grain size and type. With cryo freezing you are not changing the grain structure type/composition, rather just refining the grain structure by making it slightly smaller and more uniform. So you are not increasing the UTS etc of the component, but stress relieving it so that it wont fail at its weakest point.
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
