Also I would ask the scrutineers at the drags what you will need when you get into the 10's, if I remember right you will need to fit a tail shaft loop, I got one but never fitted it.
You can have the one I got if you want it, it will need some mods to fit but its new and to spec and has all the nuts and bolts needed, you would just need some plate for the interior side, my new project is a MX5 that I will set up for the track and it will never need it (it doesn't have the torque to pull the skin of custard).
Theres also the possibility the ATTESSA hasn't been properly bled meaning it'll be more or less RWD… Just a thought that is. I bled mine up after changing to my old twin plate and it made a world of difference.
If the gearbox has come out at any stage the ATTESSA needs to be bled
Unless its got issues thats not normally the case. Every GTR box i pulled out went back together fine, and trust me i did heaps ;)
What you can do as a cheap mod is pull the plate out of the transfer case that the line goes into. Drill and tap a hole and put a bolt in it with a locking nut on it. Spin it in a bit to preload the trasfer case. I wouldnt drive around with it locked up very tight as you will probably wear it out but it would be fine for the drags :)
As for getting your car down the dragstrip sime1, what rpm is it crossing the line at and in what gear? What 60 footer does it run and is it spinning or bogging?
I had issues trapping at much more than 128mph and did a diff gear change and now run 136mph pretty regularly. Car weighs in at 1460 and was only making 420rwkw on the Advan dyno till the turbo change.
Depending on what the cars doing there are also some very cheap mods that can be done to help traction. Some washers is all it took for me to go from wheel spinning to bogging down pretty badly. You could also ask Yavuz to set up the 2 step on the Link, from memory it is running a Link isnt it?
ATR43SS4CBB Alpha turbocharger
93 model R33 GTST Forgied CP pistons, valve springs
Stock Cams
1200cc injectors
600x300x75mm Front mounted cool
Brae high mount exhaust manifold
HPVA 50mm external gate plumbed back.
Xforce 3inch Cat back exhaust
100 Cell Cat
Profect B electric boost controller
4inch intake pipe
Adaptronic Plugin
Power 435rwkws @ 25psi , E85 Fuel
  • Like 1
Guided at 4000 / 4500 / 5000RPMs.
Per description on the boost curve sheet: 19psi @ 4079RPMs, 25psi @ 4218.
There was a split silicon hose that was unnoticed, affecting boost response. This turbocharger is going back to dyno again in two weeks time using my modified stock exhaust manifold expecting to hit full boost by 4000RPMs. It drives reasonably well on road, has a 3582's top end without the lag.
  • Like 1
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
