Congrats and good to see u are still waving the GTRS flag :)
-10s on my 26/30 was a weapon. Great combo imo!
Good to see a result mick!!!
Thanks guys, it only been 2 1/2 years coming :unsure:
I quite like the RSs on the 3.0, there's good drive down low and they push all the way to 8k :yes: makes it nice to drive and gives it plenty of punch when asked
needs more big single Mick :P
ah yes and we know you know all about big singles :domokun:
How much torque were you making . At 623 hp .
I have a 3582r going on mine kford doing my head interesting results on ya cam choice .must be very responsive I would like to know he ideal lift and duration who is making your custom cams I miggt get kelford to grind me some custom ones but knowing the spec would be great
IIRC it was about 800nm @ about 5200rpm
the cams I am hoping to get done are going to be hard on the valve train and since I have a few cars it doesn't matter if it sits around for a bit here and there, for a every day car Pauls ones from Unigroup are what I recommend, 260 x 10.8, this I have already posted in your thread
I went from 260 x 9.15 lift back to 250 x 9.15 lift on the old 2.6 and it made the same peak power just 800rpm sooner
Cheers I hope these soecs will do me well on track aswell on e85. I will talk to kelford see if they can do a custom grind
When you say will be hard on ya valve train is that because of such a big lift
How fasts the valve accelerates and decelerates. You need a firmer spring to keen the bucket on the lobe... That causes wear.
Who cares! Change them when they wear. Give me powah!!!
How fasts the valve accelerates and decelerates. You need a firmer spring to keep the bucket on the lobe... That causes wear.
bugger, you beat me to it
the other thing that concerns me is the belt, it is basically a rubber band after all, and yes, all in the name of powah and going fast
The rubber band.
Yeah. I know HKS say on their vcam the belt needs to be changed every 10,000 kms.
Being a jap cam it would be soft as a pensioners turd but the acceleration (and load on the belt as the intake cam retards with revs) would be significant.
R34 GTR
593awhp/445awkw @ 24-25psi
RB26/30DETT
HKS GT-RSs, yes fancy -10s
250 x 9.15 poncams
ARC cooler
ID1300s
custom twin 3" into single 4" exhaust
Syvecs S8 ecu
has done 623awhp/467awkw @ 28psi
congrats on the results
any feedback on the ID1300 injectors?
R34 GTR
RB26/30DETT
250 x 9.15 poncams
ARC cooler
ID1300s
Syvecs S8 ecu
Went to the drags tonight
Car weighed in at 1661kgs plus 108kgs for me
And with a less then Ideal run it ran 10.88 @ 132.23mph on 24psi and was politely asked to GTFO :)
  • Like 3
Nice one do you normally drag it or cicuit ?
    • You're not the first person that's said that about this car lol. A Touring wagon GT in Spark yellow mica would be the dog's danglies 😆 I will keep an eye out for a future purchase for sure. The seats are almost like the OEM Recaros... electric adjustment for fore/aft and tilt movements except reclining.
    • Yes!! I love these! It's a shame its not the wagon though!   Thank everything that's holy that it doesn't have the interior of the Aussie delivered ones. Those seats are so much nicer.
    • I'm both sorry and thankful that you do that.
    • 2001 BE5D Subaru Legacy B4 RSK (3rd gen) EJ208 (pink injector) Twin Turbo 280PS 5-speed manual Full time 4WD "RSK" grade which means all of the above LQC option which means stock rear spoiler  I got it primarily to export to someone outside Japan who was interested. These BE5 Legacy B4 RSKs are going through a bit of a resurgence right know in Japan as they are one of the few cars from the "turbo, manual, RWD/4WD, 280hp gentleman's agreement era" cars that don't require stupid money to purchase. Which for some people might be a good opportunity to get as a base for restoration. If I can't find anyone to purchase it I will certainly be doing that myself over the long term. Why? Because it's properly fast in stock form, handles well enough for a GT sedan, there's still enough aftermarket and (if you can wait a while) genuine part support to make it a restoration candidate (<-- that will only get worse over time so it's a case of do it now or choose get a BL5 4th Gen). Mechanically it's fine, has only 89,200kms on the odometer. The problem with this car is that the body and exterior trims are weathered from at least the last 10 years being parked outdoors. I'm the 3rd owner, the first owner was the one that had it for 14 years and barely drove it, had a low-speed front impact (which didn't damage anything behind the radiator support) and got it fixed and sold it. The 2nd owner put most of the kms on it and parked it outside for the last 10 years, hence the door rubbers have seen better days but if you overlook those cosmetic details, it presents pretty nicely. There is some minor rust on the LH rear wheel arch which I'll have looked at too at some stage.  Also as you'd expect from a car this age, the clear top coat is gone, leaving a satin finish on the roof.  Mechanically it's fine (as you would expect from a car with less than 100K kms) but the steering does feel slightly vague around the centre position at higher speeds. So first on the list is to get the steering rack bushes looked at. There's also the Lock button on the remote which doesn't work, but the Open button does.... it means that the anti-theft system thinks it's always open? It seems like if you open the car and don't start the engine within 3 mins or so the anti-theft kicks in again without any beeps or signals. So if you got to start it after that, it won't. You have to push the open button again. That's how I understand it anyway. Just a small irritation but not a big problem to sort out. There's only one mod, the Wangan SPL muffler. Just a tad louder than stock. It's a really good mod for those who don't want to wake the neighbours but still want to hear a more prominent unequal length header EJ20 sound. Anyway I hope to get all those things done eventually, that is unless someone wanted to import it to their country from Japan (where I live). I'm open for negotiations as I really would like a Skyline... but this will definitely suffice in the meantime 🙂 *Disclaimer: This is how I picked it up from the dealer, minus the stuff on the back seat. I haven't cleaned the engine bay or done a thorough exterior clean, aside from spray painting the wipers.
    • Wow, even with the Audi logo centre caps. I love OEM wheel mismatches.
