Some have had issues with ryco filters around high 300's kW on e85.
I'm not sure what to replace mine with before the new engine goes in
There are a few options, I use a SpeedFlow 10 micro SS screen filter, Weldon have 7 micro fiberglass E85 safe filter
And I am sure others have different things they are using :thumbsup:
  • Like 1
Cool I think I'll get the same. $200 for the filter sound about right? I'm getting all my speedflow weld on fittings from the same seller.
^exactly
Rewired directly to pump from battery (in boot) with relay
I had my one set up exactly the same when I was running one pump. However I had issues as the pump was overheating when below 1/4 tank and pushing it. It was all fine when it had more fuel than that.
I'm at 448kw on e85 stock fuel lines stock fuel pressure with a 460
Tuned by dvs Jez
Had a flow gauge on it and is at it's safest limit
Hey mate, out of curiosity what would be your next step if you were to push it further - can you go larger in-tank pump or will you have to look at going external?
Twin 460's?
The problem is the tank lid, and getting the thick wiring through it. If only there was a cheap alloy lid available. I have been keen to make a few on the lathe, but the sealed power connectors are my main issue.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
