Yes, both gervaise and I had our box's cryo treated at Dans insistence.
both car make over 400 kw's and both get dragged and circuit driven and have done for 3 years with zero gearbox issues.
Does it work, How do you prove it. You can only disprove it by breaking the box and that has not happenned to date so I'm going with a resounding yes! It does work.
Hey Noel,
Those two cars are the "For" argument that I have heard, what did it cost and what state does the box have to be in for the process ?
Cryo treatment is relatively inexpensive Mitch, somewhere around the 300 dllar mark for the complete internals from memory.
The expensive bit is obviously stripping and rebuilding the box along with new bearings and sychros as common sense would dictate.
Cheers XKLABA & NXTIME, I take it this would be them ..btw how were they for price and service ?
Company
Ace Cryogenic
Address
Barrington Road
Silverdale NSW 2752
Phone
02 4774 0256
Edited by ezy_09s
Small thing, but I don't think cryo increases strength (technically). It works by improving the weak points by ensuring more uniform grain structures. Well at least that was my memory of it from 10yrs ago when I once read about it
I'm not a metallurgist, but according to the experts at the company that perform the treatment, it strengthens the metal by 300-400%.
The only reason why a metal like this is potentially weak is because of the grain. Improving that grain structure of the metal at a base level certainly does make it stronger.
Standard gear RB20 gearbox - 640hp at the wheels
Standard gear RB20 gearbox - 380hp at the wheels in a drift car thrashed every week for 4 years and still going
R33 GTST, GTR gearboxes all making over 500hp at the wheels, 9k rpm launches on semi slicks, flat shifting, clutch dumping/kicking and general abuse
Have never broken a single one....ever
OK I have finally made it to the 400 kw thread.
Car running rb26 block and -5's
Car made on 19psi 420rwks - I'm wrapped :D
Massive thanks to Trent & Cat from Chequered tuning who tuned the car over the weekend (wouldn't go anywhere else)
Trent tuned a felxi fuel set up on my Autronic
Also a huge thanks to Tas (Power Glide GTR) for getting the car to where it is - car has turned out mint mate :)
Is cryogenics recognised or practiced by the Japanese?
I remember when I first joined this forum and reading up on this when paul diemar was using cryogenics as well as crd...it obviously is tried and proven, however, it also seems to be a thing of the past OR ppl simply dont discuss it these days.
I've always been interested in this subject and TBH if I built another engine or box, I would use this method
I have had the luxury of back to back testing :)
R32 GTR making 600hp at the wheels
Blew 3rd gear
rebuilt without cryo
Blew 3rd gear
rebuilt with cryo
still going 12 months later, same abuse
Technically it's hardness roy, which can come at the expense of strength or "toughness" also there is the question of penetration and how deep you can reach into the grain structure.
That's sort of my concern.
Blew 3rd gear
Blew 3rd gear
rebuilt with cryo
Wow, those results are quite something ..im assuming thats just using the factory gearsets in all these boxes ?
Ah apparently not .
Its just a more uniform & consistent hardness across the part.
http://www.nitrofreeze.com/cryogenic_treatment_for_motorsports.html
Ah apparently not .
http://www.nitrofree...otorsports.html
That article doesn't make any reference to the depth of penetration of the process, which was my main concern.
Further, while it is true that it can relieve internal stresses and reduce voids and dislocation in the grain structure.
All of the effects such as increased wear resistance, point to more carbon being brought to the surface and the formation of a harder outer case (Case hardening) which I would have though would come at the dentriment of toughness when you're talking about the gearset globally ?
Not against the idea at all just need to know that it will work the way I need to to.
TL;DR basically. Lol.
One of my mates just started a new job with a company that does this cryo stuff. Since I plan to do my brakes soon, I'll ask him how much to do the rotors. Might make that skim job last a bit longer, after that they are for the dust bin,
Can you confirm that boost figure please.
Proof is in the pudding. But still dubious of the 300-400% claim. Can someone point me in the direction of a good article on this?
My understanding from the old Iron Carbon diagram has always been strength-Ductility-toughness vs hardness is greatly dependent on the rates of heating and cooling etc and grain size and type. With cryo freezing you are not changing the grain structure type/composition, rather just refining the grain structure by making it slightly smaller and more uniform. So you are not increasing the UTS etc of the component, but stress relieving it so that it wont fail at its weakest point.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drive beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
