also factor in the price of interior trim to suit the new handbrake location, plus the pedal box from a Z33/V35. i guess only the clutch is needed + master and slave cylinders and relevant lines (braided would be easy) and installation of said items. there MIGHT not be a hole in the firewall where the clutch master would sit.
better pics of the xfer case on the m35 auto? It looks like a very good match to the R32/33/34 4wd setup. does someone have a 32/33/34 intermediate shaft they can stick into an m35 xfer case?
I tend to think the 32/33/34 box is the way to go, the interfaces are flywheel/clutch/input shaft (do-able), tailshaft (do-able) and intermediate shaft (do-able). I'd be surprised if the d22 navara stuff fits, they would have a very different front diff setup
You make a good point Duncan....might have to climb under one and check it out.
The R32/33/34 is pretty do able....only hold up is the bell housing....hence the reasoning behind the Navara scenario.
Leave it Auto, get a valve body upgrade from the states for 180usd, do whatever else needs doing in the auto and get that computer shit going and change the shift times if its possible.
how is that computer tune business going at sas? or wherever it is at now..
I already have a built box, still cant handle the power I want to run through it.
The ecu remap wont speed up the shifts, they happen instantly with the valve body upgrade, the issue is the throttle which closes during shifts and wont reopen for a bit, even though its in gear. If the SAS remap fixes that, a lot of people will be happy, im going Japanese reflash when I find a spare ecu.
Not all the time, just seems to be on initial application of throttle. If I boot it, at any speed, it takes a while to power on but once it is, shifts are instant and hard. Note that this only seems to happen under 3000 revs.
The damn ecu throttle lag I have been complaining about guys, it isnt that noticeable when stock as it gives a nice acceleration curve, but once powered up its a pain in the arse. Somebody lend me an ecu to send over, please? :)
I notice the throttle lag on the stock car i have.. its kinda annoying really as when you want to boot it. you have to think ahead of everything to do it..
The guys in the states with the same box dont seem to have issues with power? could it be something more m35 car related??
as for the valve upgrade.. it looks good. pretty cheap from the states too. and doesnt look too hard to fit at all. i might look at that to get the shift times a bit better since its only 180usd or there abouts.
you got the link for it?
Has anyone priced up buying a 2004-2005 manual stagea front cut from a importer?
Might cost up to $5K
Sell off the engine for $2-3K and use the rest
Is it that simple?
Reading the "modify auto posts" sounds like a bandaid fix for a problem that is still going to remain?
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
