Makes you wonder how the Mines R34 GTR is so responsive using 2530's on a 2.6ltr engine doesn't it?
Fact is - it's not.
Once it's on boost (4500rpm or so), the ONLY reason it rips through the gears, is because the diff ratios were changed.
Can't believe the last 6 pages, talk about rubbish...
Suppose we should not discuss or try to help someone who asks for advice or opinion with some innocent banter in between. Oh well sorry. Didn't mean to distress anyone. So where do you suggest we discuss different twin setups? Maybe a forum is not the place. Can you suggest anywhere else?
  • 3 weeks later...
I know who guy who has done a heap of head work with his -5s and pushed a 474awkw With Dyno papers to show me when I was shocked... That thing is a rocket!!! He runs it 440awkw every day and only sets it at the highest when need to
I myself with all stock internals & -5s on 18psi running 330awkw
Edited by GTRAAH
^^^ that's me mate :P
That's pretty funny !!
What would -9 s on e85 with forged internals, cams, exhaust be looking at reaching (power wise)
Probably max the efficiency of the -9s and maybe achieve around 370kw, if your setup is good enough
With the right setup you can achieve 330-350kw on 98
There's one bloke on here making 370kw on -7's so I'm sure you could get there on -9's with the right set up.
If I can make 325kw with standard actuators, AFM's and a shitty 3" exhaust I'm sure you could make a fair wack more with a decently set up car.
You really won't be able to screw enough boost into it to make a huge difference with the -9's. they just run out of puff.
This.
The -7s and -9s by 7500rpm are falling off and simply out of airflow, so you can't screw more boost in if they simply cannot supply the air needed.
Joy of having them come on so early, can't have it all!
You can make near enough the same on 98 as you can on E85 with -9s IMO, hence my earlier comment stands... Add to the fact there is not one person who's ever made legitimately more than that :thumbsup:
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
