Basicly my brakes suck so i wanna upgrade after reading the 20+ pages on brakes my head is f$%ked my car is a series 2 4wd rs4.
1> Is there a str8 bolt on dba rotor for my car (with or without modifications)
2> Can i bolt on R33 rotors and calipers (with or without modification)
3> Do i need or should i use braided lines if so is there a direct replacement that is the same ie:r33/r34
4> How much fluid does it take to fill the system from empty
Most of the info in the brake thread is for s1 cars but not much for s2 if maybe the admins could seperate the 2 sections so people with s2 cars dont have to trawl thru 3000 posts to find info that would be fantastic :huh:
https://www.sau.com.au/forums/topic/255177-series-2-rotor-clarification/
Mate, here are some comments below, hope its useful. I have done the brake swap to R33GTST calipers and disks all around.
1> Is there a str8 bolt on dba rotor for my car (with or without modifications) Not sure about for the standard Rotors but R33 rotors bolt straight on (You would need to swap calipers at the same time though)
2> Can i bolt on R33 rotors and calipers (with or without modification)Yes rears fit straight on, fronts you need to get the bolt ,odified where it bolts to the strut. (Check the brakes thread it is well covered in there)
3> Do i need or should i use braided lines if so is there a direct replacement that is the same ie:r33/r34. You can use standard lines with no problems. I have heard that R32 GTR lines fit but I can't 100% certify this. Also Maltech apparently make a set which are ADR approved
4> How much fluid does it take to fill the system from empty. A bottle maybe a bit more. Brake fluid isn't overly expensive anyways.
Most of the info in the brake thread is for s1 cars but not much for s2 if maybe the admins could seperate the 2 sections so people with s2 cars dont have to trawl thru 3000 posts to find info that would be fantastic :P
AndyD Hope to find some number`s this week & hope that i can find SLOTTED ROTOR`S as well :P ,might try to get better price on mintex pad`s to will see what i can get out of them ,still looking for rear hand brake shoe to but NOBODY SEEM`S to help so i will keep looking this side & see what we get ,cheer`s chuckie
There is a guy on ebay who is in japan who is selling full sets front and rear for series 2 stags ive emailed him to see if he can get slotted rotors from japan if he can and the price is right a group buy might be in order. It seems pads are easy to access now tho but i think i may need new rotors they are badly scored i wish dba would make an equivalent it would make life so much easier. Thanx for your help chuckie it is appreciated it seems the series2 owners arent very well looked after compared to the parts available to series1 owners
Ok done a bit more digging and found these guys
http://www.japaneseimportspares.com.au/par...tegoriesbrakes/
They are agents for dixcel rotors they have series 2 fronts in stock non slotted for $295pr and he told me they can get slotted by order for around $400pr
Part #'s are
Front #321 2013
Rear #325 2016
Ive included the part #pdf for anyone who is interested
domesticcar_r.pdf
Hi Andy yes mate & lot`s don`t care,what is happening here is ELLE has new nissan rotor`s & iam going to see if BRAKEBOND`S AUSTRALIA can mach them he said that the,should find something as he found PAD`S & that was a Big + also rear rotor`s to so hope to find all brake part`s & see what happen`s from there ,i will post up or pm few how need some help i will be chasing most brake bit`s soon need to sort few thing`s out ,so talk soon cheer`s chuckie.
After reading the dixcel catalogue it seems the s2 stag has common rotors with the cima,laurel,gloria and a few other part #are the same so it gives bigger scope to look for parts
Not sure who we could contact on this forum (or elsewhere) who is in the trade about possibly speaking with RDA/DBA (or any other local manufacturer) on making S2 Stagea front and rear standard and slotted rotors for all of us???
OR trying to match up any models already made and available here, correct offset at least, with minor machining on OD maybe.
Last time i checked the Front Nissan rotors where about ($260/each= $520 pair for standard non slotted ones).
Looks like Andy has found cheaper FRONTS Dixcel aftermarket from Japanese Import Spares - non slotted for $295pr, slotted $400 pair. http://www.japaneseimportspares.com.au/par...tegoriesbrakes/
This is probably the cheapest option for now.
Ideas anyone??
(My front rotors are wearing quite thin and probably can't take another machine job).
I have taken a set of ROTOR`S in & hope to have some new`s next week,he said that he has 4 looking for them so just wait till next week ,i also have spoken with him about getting mintex pad`s at better price, he said he will look at what it cost`s him so may be few more $$ off will be sweet ,+ he said any skline stuff he can match no worries pad`s Rotor`s Clutches to all twin plate the lot so will let you know as soon as i do ,cheer`s chuckie,
  • 7 months later...
300 dia. I believe.
We (Chuckie has some on his car and I have some on order) found some RDA rotors and EBC pads that fit on the front without any modifications. The info should be in the Stagea Brakes thread.
I agree with Andy, there is too much stuff to filter thru for the series 2.
I'm just going to go slotted rotors machined down to fit S2 and QFM pads.
Is there any benefit fitting R33 calipers with R33 slotted rotors? How does this affect the ABS system?
Sorry I think 300 is for the rears, stock fronts are 290mm I believe.
yeah the fronts are 290 with a 54mm offset and about 28mm thick (best i can tell from my rotor). i haven't had the rears off yet.
it wont affect the abs system. the benefit is debatable but the basics are, R33 calipers are 4 piston fronts 2 piston rear vs Stagea 2 piston fronts and single piston rear. you also get bigger front rotors with a R33 caliper upgrade, up to 297mm from 290mm diameter and a couple mm thicker. but they aren't a direct fit as the R33 caliper bolts are a different size to the stagea ones, a retap or bush is needed. theres a few write-ups in the brake thred about R33 ones onto a S2 (if you can find them lol).
Edited by QWK32
My point exactly :D
Correct me if i'm wrong. But I'm sure R34 brakes are a direct bolt on. At least for a Series 2 RS FOUR S (manual) the are.
Anyone care to confirm.
correct, R34 direct bolt on. R33 bolt up with minor modification.
  • 3 months later...
Your head might hurt after this.
RDA954S are only 296mm in Dia, I'm pretty sure late model S2 have a bigger Rotor
What end are you talking about? Not sure about rears but fronts on S2 RS4 are definately 290mm (I have measured mine, I actually measured 289 but anyway, 290 sounds good).
Maybe if its a Autech 260 or something.
Pretty sure rear rotors are same as a skyline or something.
I'd be careful about saying the fronts are the same as a cima,laurel,gloria. Maybe a particular model of them. I have a gloria (think HY33) front setup on my r31 it was the same as R32/Z32 rotors.
Other info:
Front pads: GSL 009 (From GSL Rallysport) in two variates: HPX (Bendix Equavelent) or A1RM (for motor sports) www.gslrallysport.com
Rear pads: Bendix DB1399
I bought both sets of pads from GSL Rallysport and got free post.
Some poeple have said the rears are same as R31, I have both (r31 and DB1388) in front of me they are different but i haven't fitted the DB1399's yet. Will confirm in the next couple of weeks.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
