@@@@@ GUARD FLARES @@@@@
Hey Guys,
Go to www.r31skylineclub.com, then open link to Forums, then scroll down to trading post, "Parts" and fatz (Pete) has a group buy for $300.00 set delivered.
$50.00 deposit gets it all up and running.
Cheers.
  • Replies 2k
finally got my car sorted - took it for a spin and...hello boost
noticed a few things - brakes need serious attention, tailshaft hits somewhere and also i cant get the grin off my face hehehe
i found that the changes i made to the brakes are great (for now) r32 master cylinder, slotted rotors and good pads, but if you do some minor changes you'll notice a change! pads, fluid, machine the rotors things along those lines, in the wet the other day pulled the car up from 140km to 40km in around 60m, dont think i've had a car with that kind of stopping control, i do have brand new tryes on though!
mate it goes a bit better than the L20et dosent it, i run mine around the block a few times with no intercooler and then once the cooler was hooked up took her to work with me :aroused: mate the boost on mine kicks the rears around a bit, worth all the money i've spent so far the first time i dropped the clutch :headspin:
ANYONE NEED ANY BITS FOR THERE CARS AS I'M TAKING MY MR30 HATCH TO MY MACHANIC ON TUE TO TAKE THE REAR CALLIPARS OFF AND THEN TAKE IT TO THE WRECKERS SO IF YOU NEED STUFF PM ME AS IT'LL BE AT POSTAGE COST TO YOU?? cheers.. Matt
']arent those flares for 31's though? hmm id be interested but i just dont have big enough dish & spacers to make use of em! would make my wheels look tiny! lol
They are! BUT!!!! if you go to the Jenesis site, www.r30.co.jp and open the BODY link, you will find "Fender Trims" and the picture of the carbon bonnet shows them, they look identical to these R31 flares.
I don't know if we need them unless using huge wheels, like 9 inch + wide.
I am not going to fit them until after the adjustable rear goes in, to see if & when the rear wheels are at zero camber and toe, how they sit in relation to the body, and I have 16 x 8's all round.
Cheers. :ghost:
Cheers. :ghost:
i'd say they would be good if we were looking at the gtr brake upgrade as i have 7" and 7.5" wide rims and they fit perfectly if i run the gtr front brake set up and these rims i'd have 1/2" gap!
RE: Flares
You'd have to have some pretty wicked offset wheels to make use of them I think.I have 9inch rears,on an HR31,and I know they're different,but they it good.Also a mate's old DR30 had 9" rears,and fitted snug also.They were Sparco Python2's though,so not that deep a dish.....
Also,I think the local boys are getting them done from fibreglass?
RE: Flares
If you went back a few pages to the link rsx84 posted about the Japan R30 Meeting, it was then discussed on wether these flares were available here???
I simply say, they are and from where. R31 Skyline Club are getting them made locally (Sydney).
I don't think they are necessary either, but I won't know for sure untill I get my camber on the rear wheels sorted out. Once I get the rear wheels to zero or -1 max, I won't know if they are needed.
I have 16 x 8's on now and they sit fine, neatly inside the body without rolling the guard lip, and the wheels are +38 offset, (std is +25) and I still clear the coilovers on the inside.
I don't know if I can get 9's on, but I will see later down the track.
hmm interesting.. i had 17x7 +38 offset wheels on mine and they sat in the guards terrible, had about 7-10mm clearance between the strut and tyre.
and they also rubbed on radius rods on full lock
s13 coilovers almost bolt in, the front strut tops are the same patten, for the rears i swapped strut tops. They work a treat for me and so do the big brakes, i bought a set of JIC coilovers for $500 :)
On the topic of custom parts, Ghostrider is right, its cheaper to have them made, at the moment i have a half cage, castor rods, adjustable front control arms, rear strut brace, rose jointed swaybar links, rear floor brace, custom oil catch can, custom inlet plenum and a few other items being made up here in adelaide for a reasonable price.
You can slot one of the swingarm mounts safely to correct camber problem in the r30s, works a treat, but be cafefull who does it, best left to an engineer.
Picked up an LSD on the weekend at a cheap price, but its a 3.9 ratio, i was looking for a 4.4, does anyone have an R200 open wheeler, or crownwheel and pinion in a 4.4 or 4.6? I plan on swaping the LSD into a housing with 4.4 or 4.6 ratios.
Also picked up a very thick K-mac front swaybar.
Im interested in a t-shirt too :D
OK just a quick question when i got my dr30 "iron mask" months and months ago the iron mask was coming off at the RHF section. The question being how do i fix this? is as simple as a industrial staple or some sort of clamp? the thing is it was attached by the japs with what looks like masking tape, interesting? Another quicky can we install a australian standard battery, is there enough room? actually theres another one do i have to buy the window seals or can i get them made up by someone?
I know these are dumb questions, but still....
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
