12 month personal imports are still around and will let you bring anything sold here locally, into the country. So yes, you could bring in a GTR if you want. Proof or ownership in whatever country for 12 months is required, rego papers, etc
But if you did this in Japan, which i've thought about, and not live there, storing the bloody thing would be so expensive.
Almost tempting to live, work there for a year, get paid in Yen, and buy a car... yeah you have to store it, but i'd imagine you'd come out in front at the end, Baron?
thats my plan when i finish uni :)
How much are they going for in japan?
  • Replies 245
Posted Images
Well I've got it got it now! And damn it's awesome to drive.
A couple of little things Oz people might not be aware of. There's no SD card slot for the HD and no iPod adapter. There's also no auto head-lights or wipers (same as US guys).
But the series 2 premium wheels in the day-light look AMAZING and I'm totally blown away with the quality of the paint finish on the whole car. It has a truely amazing pearl flake in it.
And finally for anyone that is in Vic and is keen to look at a car - Nissan Ferntree Gully actually have a demo car down there now to have a play with. It's a Red Premium and looks hot!
Congrats on getting your R35 man, they are truely amazing to drive.
So ADM only has the Harddrive cd ripper? No other way to get your music on it?
Does it have a DVD drive or CD?
Also - at this stage there wasn't an option for ANYTHING - that included extended warranty and even something as simple as a tint.
Well make sure to get a really really dark tint as you become a instant celebrity driving these cars LOL
FBI Tint, pearl white GTR, gun metal rims = teh ultimate hotness.... add to that the black A pillars.... totally drool worthy...
If you want to give it some proper paint protection Andrew, take it to Damian @ Final Inspection... he'll make sure the paint gets the best care possible :P
So you can organise test drives at FTG Nissan???
Yep - only has the CD ripper. And even at that it won't rip MP3 cd's (it will play MP3 cd's but won't rip them onto the HD).
And a normal CD takes around 15mins to rip. It's definitely not the cars greatest point.
But go out and put your right foot down a few mm and all is forgiven :P
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
