Paul Walker needs one of those 500+ awkw R34 GTR's. He'd appreciate that sort of power and probably enjoy the ride.
Vin Diesel just needs a really tough looking muscle car.
I don't think they'd like it if you were hooning around with actors - they'll probably only get you to drive a few kms (if that much). Just guessing.
I'd love to see what Vin rocks up in. :ermm:
  • Replies 181
What about your brothers 4 door and aristo?
lol noway, cars arnt wild enuff, they wouldnt suite the whole fast and furious theme..
u need a riced up car with power too! ok ok the aristos rice, but its n/a
thats why i think the Chasers halloquin r34 GTR with the titanium lipped gram lights would suite the role perfectly
if they are true to the movie, they will pick a good base car that has been made to look retarded. we can only hope they would choose something nice like snowballs, aaaaarons or that white 34 from perth to give it a bit of.....something nice.
on the other, take james up on his offer. i would love to see something like the superleg with a shopping list and a rediculously big gay silly sticker of something random on the side..
Not only does my car not have back seats due to the cage but it might also have a slight conflict of interest in movies at this current stage! LOL
That looks like one of the characters of the disney movie "Cars"
thanks for the emails and rather amusing posts.
In Syndey will be using a Z-Tune for Paul and IS250 or 300C for Vin
In Melbourne will be using Matt's R34 circuit car for Pual ( might have second GTR as escort)
and the Supercarclub will be providing some bling bling for VIn
Before the comments start, Universal made the final decision and they are not car enthusiasts, they know jack about cars and couldn't care so there decision was based purely on: "wow, that looks great"
thats awesome. congrats Matt.
now just get Paul to sign you car and take a pic of him signin it and it will be worth billions lol
main selling point"signed by and escorted Paul Walker" lol
damn i was gonna put my car in.
Paul would have been able to appreciate the Motec system exhaust!
Congrats on the win matty. i wanna see you make Paul soil his underwears on the trip over there! :)
Hey Andrew, long time no speak :laugh: I'm down to do this if my car is considered for it. Sent you an email with some bigger photos
+1 for Matt's GTT!
Yo Matt you coming on the GOR Cruise man?
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
