kwickr33:
Yes we have internal wastegate kit for your turbo. will cost $200 with bracket and high pressure actautor.
Gtscott:
We buy Garrett bearings, seals plus certain bearing housings and we do our own assembly.
Hey Stao, I'm looking to upgrade to a TR43 G1 with a .63AR in the next month or so.
What sort of wastegate actuator options do I have?
I know you don't typically make them with anything less than like 10psi for skylines etc.
but for my X-trail, i need a low boost setup to work off before i raise the boost with a controller.
If I was to order one, can you include a 5psi actuator?
Thanks!
Little update:
I've managed to build a "HKS2530" in a larger .86 T2x turbine housing with OEM RB25det bolton pattern for RB25det engines. Should produce identical amount of power with similar response and better torque for the Rb25s.
Photos:
any chance you have a garret gt30 ex hausing with rb style flange on there do you?internally gated if possible
Yes we can do that.
The GTRS would be a smaller trimed 2871R. I'm also building one with larger comp trim. My engine is almost finished. I will put that on and see what happens.
im just looking to buy a garrett gt30 rear exhaust housing,i believe the genuine garrett option is best suited to my turbo,gt30 71r non cropped turbine
The genuine Garrett GT30 internally gated turbine housing I have a listing for $650AUD including GST brand new in .82 A/R.
Can i ask, which turbo and housing is best for r33.
Thing is: i dont wanna upgrade injectors, PFC, z32 etc.
I just want to run MINES ECU, Bosch fuel pump, exhaust and cooler on 14 psi, (stock injectors and z32). So around 225kw is probably aim, but would have to be responsive.
Stao how are you mate...
im after a turbo for my car gt 3540 - 2530 but i want the power of the 3540 with more response... is there a half way kinda turbo out there td06? or something i was told.... now im after 230 awkw on the gts4 but im gona want more later on..... ive spoken to you late last year.. about this but theres so many to choose from.. whats gona be best for my rb20 ?
regards George
That is the easiest question ever to answer.... the factory turbo, as your Mines ecu is tuned only for the std turbo and std afm. It will run with the z32 but the map scaling will be up the shit.
If you do swap the turbo it will just be a matter of time before you have a nice mess on your hands.
regards George
A gt3540 will make 400rwkw a 2530 will make 230rwkw..... big difference.
Hi George you can use our ATR43G3 in .63 turbine. It can get you about 240~60rwkws internally gated on RB20det with full boost around 4500RPM or some thing like this:
This is a ATR43G3 .63 turbo with built in External gate that is designed to bolton to stock RB20det's manifold, dump, and all lines.
Above was built for a Rb20det customer.
Also like to add all of our HPVA external wastegate are equipped with a Genuine Tail 38mm external gate Diaphragm:
Stao will the ATR43G3 in .63 turbine do 230-260 awkw comfortably ? i dont wana be driving around on 21 pound lol
also if i can get 260 kw i think thats plenty coming from an rb20... might stick to the atr43g3 with .63 also price it with internal gate please ta!
Edited by v8tzr
Yes you need to run 20psi to get about 260rwkws with stock rb20det. This engines need abit of boost to make power.
For comfortably I would say around 245rwkws. with about 18psi of boost.
Price? on one of these? will be purchasing within the month..
Price on those is $1450 including braided oil feeding line and GST. will cost $150 more If you want external gate built it, which is highly recommended for high boost applications.
This also includes 12 month warranty for all high performance applications. Means your warranty does not void if you run 24psi every day like I do and drift it 24/7.
hey stao,
Im running the older version of your turbo turbo the tr43i .63 on a r33 on 17.5 psi and getting fullboost at about 4500 and 260kw, wondering how much difference your new atr43 g3 would run? would it be less laggier?
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
    • Are you 100% sure this isn't tune related?
    • 140-150 across the board. At this point hoping the grounding harness fixes it. My grounds are all tied to the chassis and none to the battery. For SR and KA that’s never been a problem for me but had a few other guys here and Reddit who told me RB really like a very solid ground setup tied to the battery so going to try that next, I’m stumped if that doesn’t do it. Never had a car have spark and fuel and not fire off before. Only thing I can think is the spark is intermittent/weak because of grounds nothing else really makes sense at this point
    • I am having close to the same issue. Can you help me with what wire you grounded to get your pump to trigger?
