How ever I would expect Hypergear's units to out perform Kando units since their project is soley based in Rb25det and they have a test car. Looking forward to see some results.
Kando T67-25g 10cm is a direct copy of a Greddy T67-25g 10cm which was designed in Japan by a massive company with huge experience for 2.5L applications so I would say that point is null and void, if not a little naive.
Saying that, I have owned both a Kando turbo and a Hypergear turbo. Both are great turbos, good value for money and would (and do) recommend either to anyone who suits their application.
Edited by SimonR32
I really find Hypergears sevice fantastic!! seriously i have even rang him at 7 at night with questions and he still is polite :) And also seriously i would of thought that keeping a name like that in Australia would be much better than someone complaining over a few $$ but is more up front but less in the long run once u got the car complete.
To buy and fit one of those turbos you be looking to spend $900 delivered. Then another $800 on a decent manifold, $300 on external gate, $300 making dump and screamer pipes, $200 on water/oil lines and fittings, $100 on gaskets, $100 on intake pipe. By that time you've already spent $2700 plus 10 hours of labor, 1000% defect rate.
For $1850 I can get a ATR43ss2, bolt on, all it cost me is 3 hours labor, at 320rwkws It will out perform that $2700 setup.
Obviously it cost more $$ if the turbo is more involving to make, but price for value based on the final out come is still very cheap.
I have said across many threads that a Hypergear unit will save the majority of entry level modifiers an all out packet. I know they are excellent value, and I know they work well.
If you read back my previous posts in this thread, I do not have an RB motor and do not need the specially designed RB outlet flange, my comments on price are based on a generic unit supplied by Hypergear and not the specific items made for skylines. If I still punted an RB then I would happily own a hypergear turbo at the said $1450 for an SS-1.
Stao, $1200 is a good price and I will keep it in mind, Thanks.
Hi stao a while last year you built a highflow turbo for a friend of mine (pu flow) for a R34 GTT as i did all the installation i was sure it was fine... its recently being worked on at DR DRIFT (installing injectors rail and FPR) but a massive leak was discovered.... now the leak is coming from the comp housing o ring.... i was just curious since the building of the turbo was done by you are you able to fix this problem free of charge because its a build fault?
please pm me asap!
Happy to have a look at it, bring pass when ready. Generally you won't get any oil passing through the shaft collar on the cold side unless bearing housing is flooded. I would be checking the drain side.
He mentioned it was a leak, but not specific to an oil leak.
I assume an airleak was discovered which is why the compressor housing o-ring is being blamed. If the comp housing has not been rotated since build I would consider this a fault.
If the comp housing has been rotated even once since, I would not offer any warranty on the product. Its a 30c part anyway, personally I wouldnt bother returning it to supplier.
Some minor updates:
Suffering from major set back as my R33 had its 4th engine failure. Been told cyc 3 is down in compression and filled with oil. Likely is from that dyno run which the AFM plug vibrated it self out, it made a very bad detonation and the engine had with a little rattle since. Time to rebuild again will updated with photos
Also I've had a small batch of SS-1 castings produced, and by making them in quantity I've saved in average of $200 per unit in materials and labor so they are now $1450 inc GST, high pressure actuator and braided oil line. That is a perfect upgrade for any one who’s chasing 250rwkws in factory response with plenty of usable power band.
Some minor updates:
Hope you can get the test car sorted soon I look foward to seeing some pics of the repair/rebuild shortly!
Also good to hear you are cutting costs with batches of turbo's being made im sure it will help people out with better turbos for cheaper prices :)
Further updates:
This is a fully overhual and high flow service for people with Ford XR6 or any Generic GT3582 turbocharger. Including:
Brand new CHRA assembly using machined alloy comp wheel with larger blades. Fully machined .70 comp housing and high pressure actuator.
Beefed up turbine to bearing housing adaption area. Pretty much all of them are cracked.
Ported wastegate and larger wastegate disc
The estimate power out put after high flowing is about 680HP, Standard is about 560HP due to limitation from .50 comp housing.
Some update:
Have had the engine pulled apart last weekend to find out of what appears like my mechanic didn't secure the gadget pin's retainer probably during the first rebuild, the pin slide out rubbing the block.
Leaving a very damaged bore.
Ethics its a funny thing, this is a licensed mechanic that I've used for the past 4 years, forwarded many jobs to and pretty close mate with. After diagnoses eliminating faults from hydraulic lifters, I was under the impression that I've got a broken piston from earlier air flow meter incident, so I naturally forward him with this job, how ever he stopped responding to my phone calls ever since.
Any way it’s not looking bad for the up coming engine. Getting it done at a proper engine building workshop. Every thing will still be build back into standard specifications for further Rb25det turbocharger evaluation purpose.
and this is why I trust second hand motors over rebuilt motors even from proper experienced builders. Even when people are spending upwards of $10k you see things like this happen
Edited by Rolls
Hypergear's engine building mate. Obviously doesn't want to take the rap for doing a half assed job on the engine. When it comes down to it, a lot of people will choose money over friendship.
I gave that block to reflex (local engine building workshop). I'm looking for another block at moment but they said they might be able to sleeve it. So I will wait and see.
Also I've had a second hand rb25det earlier. Lucky I stripped it for a quick check up and found 1 broken ring land in piston 4. So I would prefer to rebuild, but once again not really worth it when job's not done properly.
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
