Its honestly just sitting pretty ATM. Just PM me an offer and I'll consider it.
It needs a basic clean and recheck with a straight edge and its good to go. Valves/springs/retainers still in place. Will need to look for the buckets, cams are VCT and rusted.
As stated, welded to suit RB30 block, not non VCT yet using typical R33 DET head means easy fitment with Freddys ETC
considering just getting a Kai highflow done on my 0p6 stocker.. should do atleast 270rwkw and full boost around 4000rpm and its LITERALLY bolt on/off.. $1370 and thats it. or is it, i dont know how the stock intake would hold up to it - Stao?
anyone have any updates on their HG turbos?
Not any real updates as of yet, but may have figured out a possible fix for my problems after speaking with Matt from NIStune. The TCS error code is possibly causing problems by pulling fuel unexpectedly. This may be fixable by reprogramming my board with a Stagea image. The boost sensor DTC is similar story, the stock ECU needs the signal from the stock solenoid because it uses boost control tables, but that was removed when we installed my engine and the Greddy Profec.
So I'm slowly working through my issues, nothing concrete yet though.
Why don't you just take brad's advice on how to fix it?
Edited by SimonR32
He didn't tell me anything that I didn't already know. This was his last PM to me:
The Trc code. You need to make sure its plugged in. Its the Brown plug on the back of the TRC motor. Not the main TPS plug at the front. If you dont want TRC you can get rid of it completly but that a little hard to explain. This should rectify both of you abs and TRC codes.
My Car has a Greddy plenum so Its not the same . I think it still has the Abs DTC in there as I dont have TRC anymore.
I Never had it tuned with these faults so I dont know if they would have affected it at all. I fix all the problems
Beforehand as it put the engine light on.
But I do not have TRC, it's been deleted. I have no intention of wiring it up either, I'm not interested in it and the plan is to go forward facing plenum in the future anyway where it would just have to be deleted again. I did ask him how he fixed it with TRC disabled but never got a reply.
Edited by Hanaldo
Yeh see that would mean wiring everything up. I've got the throttle body and the sensor on the back of it but it's not connected to anything. Would work if I was doing what he did by going to forward facing and the stock setup was all there.
May be easier to use the Stagea image if it works.
Hanaldo, i have the stagea ecu in my R34 for unknown reasons if that helps. Its running R34 maps though and Nistune. No probs, just dont have TCS/Slip, no light nothing..have the dual butterfly in the Tb.
Hey guys,could anybody tell me the size of the dump pipe bolts?
I've just ordered a jjr 3" bell mouth (rb25) and searching has proved fruitless for me, unless im typing in the wrong phrases.
I'm not at home for another 2weeks and would like to have everything waiting for me when i get home.
Cheers guys
P.s Great thread,lots of info
They are M8x1.25 from memory, someone confirm??
It doesn't say if the order comes with anything else so I ordered the permaseal full gasket set for the upcoming highflow purchase.
After reading a few posts on the subject, I thought it might be worthwhile replacing them. If they don't need replacing then spares will always be handy to have.
Thanks for the help guys, M8 1.25 it is. I'll try and get varying lengths and the 10mm head is a great tip Jez.
Can u not use the stock ones? I got bolts n crappy gaskets from just jap when i got my jjr pipe.
You can, but keep in mind that these bolts are 12+ years old now, they've seen a lot of heating up and cooling down. I considered myself very lucky when I didn't snap any of them getting my turbo off for the first time. Better to just replace them in my eyes, makes future removals so much easier.
I actually changed to allen key studs on my last turbo install. Makes getting THAT bolt out a breeze :D
Hi Tao, wondering what the differences are between the SS1 and SS1PU? How much would it cost to make my SS1 into an SS1PU? Is the SS2 a completely different turbo?
First of all, happy new year every one.
SS1PU is a totally different turbo to the SS1 and I found its a lot better turbo with similar sort of response. Pulls lot harder.
I'm currently evaluation CBB G3, customized turbine housings and few different billet high flow profiles at this stage, will have some results posted soon.
I thought you did away with CBB tech? Many of the good/reliable turbos out run journals anyway, so I dont understand the need for change.
Keep your cost low and reliability high :thumbsup:
    • Agreed, I've never seen a 260RS specific manual. As GTSBoy said it will mostly be stagea other than the engine loom https://www.hgeconsulting.com.au/stageaservicemanual.pdf
    • You'lll likely have to make do with R33 GTR for engine/tranny stuff, and Stagea for the body. I don't know that there's even been an actual diagram seen in the wild.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
