JET 31 - Why dont u want maximum torque? Thats the funnest part, yes its more det prone there but if the fuel is good enough then there is gains to be had, then let the boost build to redline and make crazy power figures.
If only...
I was just talking about using 98 octane, not unlimited octane, would be a nice old juggling act with timing on 98..lol, i have had freind long ago just do this with WI, standard T25G;s
on Sr20...25psi coming on and through midrange and 16- 17psi up top which is all it have it give, 111-113mph traps on a T25G in a silvia ..not bad..
cheers
darren
Hey guys
I'm working on a 250kw RB25 setup
Tossing up between the ss1pu or the ss1.5
It's going to be a street car and I want something that pushes you back in your seat and makes you hold on
Makes power early and can hold 250
Read the charts with the differences between the 2 and saw the 1.5 made better numbers on lower boost so I guess this would be the way to go?
What's the difference in the 2 other then the $250 price difference?
http://i.imgur.com/WxXlQ.jpg
definately gets the 'whoa!' feeling :)
Ur on ur own with that one. I see it as even if u have the power to break traction, with the correct throttle control u can be just as fast
Not with a Gt42 and 400+ wkw and 200rwkw of that over say 500rpm of the powerband coming on ..,lol its so toey it impossible to control and the faster you go, the worse it is, because you are applying more load and need far , far less throttle input, all you can do is setup sus and tyre selection
cheers
darren
Edited by jet_r31
Thought i would chime in with my findings so far on my ATR43G3.
Firstly, hats off to Stao and his mechanic that can get one of these suckers fitted in 4 hours!
Took it for a little drive around the block. Using 1/2 throttle, i got it to 4500rpm 1 or 2 times just to see whats up. A nice spooling sound and exhaust note is whats up! It seems to run/idle the same as before (tuned ECU), but i know not to give it the beans until its tuned properly.
Changing injectors tomorrow so if all goes well its getting tuned on monday.. Then drags on wednesday. :devil:
Would be good to see some mph from these things!
cheers
darren
You're not gonna try to drive it to Ovaboost after doing the injectors are you??? I'd bring a couple sets of replacement spark plugs if you are :P
Also keen for results from the tune/drags :D
Lol, i've since decided to change them in their car park. :thumbsup:
Edited by LANDSCRIBBLE
assume the wheels, shaft, bearings, and housings are re-useable. That will cost you $400. If every thing are gone and only housings are good then its not suitable for rebuilding. That will cost you $800 which is high flowing to 2860rs specifications. So the worst case scenario will cost $800.
Hey Stao,
What would be the highest figure you could expect from a SS1PU without putting to much stress on it?
I see its rated to 470HP which if I am correct is around 350kw
I am looking to purchase on this week.
Thanks
SS1PU makes around very responsive 260rwkw mark running 18~20psi. 22psi max it out at 280rwkws which is the most this turbo can do internally gated. This turbo has no issues handeling boost.
For the GTiR rebuild, $400 covers: 360 degrees thrust bearing, bush bearing, collars, seals, sand blasting, balancing and assembly.
Drop the turbo in when ready. I will need to pull it part to give you an accurate quote.
Some Modifications that I've done to a stockie R33 21U turbo:
Would be awsome if I can crack 300rwkws with it internally gated on pump 98. :D
Turbo's installed today:
Looking pretty stock :D ?
Initial test drive, it builds up boost very quickly. Dyno tune due in soon.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
