The logic & experiences of the split dump pipe being a restriction makes sense to me explained in that way. Thanks GTSTScott, Rolls and Birds for the explanation.
In any case buying one of these is not a hugely expensive gamble for me, so I will just have to wait a while, get one & sell the current one, and see how it goes.
Because retuning is fairly expensive though, I may want to make more changes than just the dump pipe to make more sure of getting more power. Finding out the dump didn't work & that it is indeed the FMIC after another retune would be a bit painful.
Another point to note; when I was speaking with Tao, and he asked what intercooler I have, he was of the opinion that even having a FMIC running the normal path (not turnflow), the only coolers he had seen consistently perform were Plazmaman ones and PWR (which he has on the test car). I asked about Blitz turnflows and he does not think these are reliable either, and definitely not anything JJR.
The problem with the JJR return flow and short vertical run down cores, is not the ability to flow, its the ability to loose heat. They pull one good run then heat soaks every run after, so your car would pin, pin, and more pinning after each run. Don't remove timing, give it 20 mints cooling period between runs and its knock free. I've already tried that and mentioned it in earlier pages.
Obviously when running E85 with a cooler like that, the fuel is not as sensitive to heat, so as long as it can flow it will make power.
I believe Jeff wrote a full page long about testing of a blitz return flow cooler that caused boost drop issues, if you haven't seen it please refer to index page for the thread.
In conclusion don't use return flow coolers or crappy cores for 300rwkws application. Spend some cash and get a decent plazaman cooler (abe's car G3 making 290rwkws pump and 358rwkws E85) or a PWR cooler (test car). The importance is in the quality of labor work, and materials its made from.
Split dump will do no good. It causes boost creep and flow restrictions specially used on the G3. There has been few pages of discussions to read at, they can be located through the index page.
Plus there is no magic in the engine. Every single part in its build is listed in previous pages.
My return flow is performing so far. I also have cooler piping from turbo is 2inch then near the cooler it opens to 3inch. Then from the cooler it drops from 3inch to 2.5inch to the throttle body.
This car goes against the norm
yeah mine is only 60mm all the way to the cooler too, then 2.5 to intake..not return flow though..
Smaller piping helps keep up velocity up which is good for response..thats my theory anyway..;)
probably not great for big power though
Silicon will be alright for a 250-260kw setup?
yes, with abuse it may give way over time but should be fine for ages..
Hey Guys
So this is what I mean by the welding its right near the sensor
Ah mine has a ridge about half an inch behind the flange. You have the same ridge but mine seems to have separated and is now raised. I'll try get a photo up later
As long as there are no kinks/abnormal stresses on the joiners, and the surfaces being joined together are free of contaminants, I'm absolutely positive there is no way you'll run a higher boost pressure than they can handle. Quote me on that.
Also 150rwkw @30psi is more likely to blow joiners apart than 700rwkw @15psi.
Oh also, I'm fairly sure that my boost source is plumbed much further than 30cm from the turbo...it's on the cold side of the intercooler piping, as it goes back over top of the turbo.
I wouldnt say dont use return flow coolers
i have a ARC return flow on my 33 with my gt3076 yet to be tuned
but my best mate has one on his r33 and makes 307rwkw on 18psi internal wastegate with a ARC and doesnt see any pressure drop or rises in intake temp
i guess its all todo with the quality of the cooler
i would always prefer a more expensive cooler to retain the LEGAL well the stock HOLE route rather then cutting a hole
Is there a certain way about doing it?
Hot side or cold side of the intercooler
When you say back over the turbo Troy do you mean just before the throttle body?
nothing wrong with cutting a hole if it is done in the right place.
not entirely true, NYTSKY's R33 GTST made 427rwkw with a china spec 76mm front mount intercooler
Not quite that far, more around where the cold side piping goes back over the pod filter. Either way,like 40cm before the throttle body
In Melbourne Vic roads new law in there book says no holes to be cut in the body if it's not from factory, can't even cut out a parcel shelf to fit 6x9 speakers
In that case you could very easily go to a mech engineer and get them to sign off on it if it is a non structural part of the vehicle. There is ZERO issue with cutting into non structural parts.
Makes no sense to me.
Its good to be consistent in what we talk about dude.. Try to remember an ARC cooler goes for 1-2000 dollars new, its not exactly apples and apples when you think of it that way.
Long story short, ARC are a fu*king good cooler.
A good example of this is the 3071 with a 0.63 rear that made 307rwkw on a neo r34 with poncams, made 290 with stock cams, only ~18psi as well, was tuned by one of the guys at nistune themselves and on the morpowa dyno here in Adelaide, reputable tuner and not known to be high reading dyno by any stretch. The dyno picture is in "matts r34" thread on the nistune forums if anyone wants to check it.
Guy had all of the most expensive jap brand name (overkill) parts as far as intake, intercooler, exhaust, dump etc goes, the engine was also extremely healthy (neo as well). I think this really shows the merit in good quality parts, no leaks etc as this result is normally what is seen on a gt3076 with a 0.82 rear.
In regards to where to get your boost reference signal from..
The way I like to do it is for the actuator, shortest possible path, as close to turbo exit as possible.
I then get the boost reference for the EBC control unit from the plenum.
This is how my stock turbo was setup but now going to have to use a silicone joiner
So I will do just after the joined but before the intercooler
Right now my EBC gets reference from the stock gauge line
Just after the elbow is fine, you just want the actuator reference signal as short as possible (i.e. not on other side of the cooler) to prevent any overboosting or lazy signal issues.
My new setup will have a peak recall boost gauge plumbed in with the actuator reference signal (so I have pre cooler readout) and a normal boost gauge + EBC signal (EBC has peak recall) at the plenum. This will then show me any pressure losses and help troubleshoot issues :)
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
