^^^ Agreed.
What are they doing Birds? Fit turbo, fab intake, tune car, there's a day. Why so slow?
He did have that issue with his injectors.
But... It's a workshop. A good workshop, from what I've heard. Good workshops are busy, even simple jobs take time.
Sorry guys, picked her up lastnight and have been busy since. RP were under the pump and down on employees, they have so many cars down there to finish lol.
R33 GTS-T (~150,000km)
Apexi pod filter
Yellow Jacket coil packs
3 inch turbo back
Blitz CS FMIC
Z32 AFM
Bosch 040
Nismo 555cc
Power FC + EBC kit
HG SS1PU custom (Nissan comp housing instead of ATR43)
258.6rwkw @ 16psi on Shell V-Power (98)
Second line is a slightly safer tune with some pulled timing and more fuel, making 252.4rwkw.
And that’s with:
An internal wastegate
Nissan comp housing for a standard looking turbo
Cat and Varex muffler (Varex supposedly costs you power, I disagree personally)
Return flow FMIC
Standard intake hose
Standard BOV
Comments: This all makes for a quick, responsive and standard looking street car. It is lovely to drive in daily traffic, better than standard. Stao warned me that I would be down on power due to the above restrictions, so I daresay there is potential for more in the top end and all over the place…but…my aim was to make it fast and keep it looking stock (see pics below) with a very safe tune. I think we’ve achieved all that! Thank you to Stao for a great turbo and Race Pace for an awesome tune.
Will be throwing the standard airbox in when I find it, so that the boys from the EPA “can’t touch this”. Oh and…stay tuned for E-flex :)
Good result Birds, is that pretty much what was expected? I'm not sure how the standard housings compare to the ATR housings, but 260rwkw seems like that's about right?
*EDIT* Same time post haha, sounds like you achieved what you wanted, well done man :) Gotta get this plenum and new fuel system done on my car and get it back on the dyno without the ECU problems now! :D
Edited by Hanaldo
WOW. For such awesome results it is so surprising to see how basic your setup is.
I love the fact you did so well with the stock nissan comp cover, rubber intake and stock cooler piping! Those all would hold it back from maximum potential in my eyes, and you did really well!
Props to all involved!
Nice graph man, I see you still have the standard rubber intake.. Not sucking shut? Maybe 3-5rwkw to be gained there by going 3 inch metal..
Speaking from experience? ;)
Lol thats a pretty awsome result there birds, Looks so stock. I too would be worried about the rubber intake sucking shut though, with all that extra suction its creating now. At what psi is it getting 16psi?
I thought you mentioned sometime back that your $400 intake pipe got you approx 3-5kw? :P And your HKS sticker on it made it cool.
I'm really looking forward to when (or if) you finally commit to modifications, it will be good to see how many corners you cut to make it cheap and how many times you will spend more money than you thought you would, as those of us who have actually done it can tell you it's going to happen. It's gonna be a real blast.
Speaking of things that actually happen, that reminds me; Birds didn't you say RP were making you a custom intake pipe???
Edited by Hanaldo
Yep, well more than expected to be honest. It's not far off Stao's figure and there's plenty more that could be done to free up killerwasps. Tempted to venture down that path, but I reckon E85 will do much more for me and retain the stock appearance. Stao believes that the ATR comp covers flow slightly better than the Nissan covers...but they are roughly the same size so I was willing to give it a go.
Cheers man! Just wait for E-flex...visually it'll be no different, but the graph will be a different story!
Nah not sucking shut at this poundage. RP put a metal spring in there (similar to the GTR setup he said) which helps to keep it open...if it presents a problem down the track or when I tune on E-flex then I'll do the metal intake.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
