I wonder if the FNT design has much to do with off boost being so driveable? Given it's a more efficient use of exhaust gases when you need them most, i.e. for the initial spool, perhaps it is helping out there? I imagine the bigger rear housing would make a difference over the standard housing too.
The FNT change was fairly well doc'd and Stao noted massive improvements in the driveability of the things. The most recent FNT revision to the G3 has it looking as good as a Kando 20g on spool and surpassing it on power! Yet on paper and on road could be different, I could not be sure unless I drive both.
Just wait til I go E-flex boy!
Must.. Resist.. Troll..........
You crack me up birds... :rofl:
:blink:
Oops...forgot you weren't a supporter of that there fluid lol.
LOL no I am a supporter of it, when its setup to be what it should (content sensor ECU and ethanol rated consumables in place).
The results are nonsense, but I cant justify the cost/effort when its hardly 'available' in Sydney.
Well maybe if more people were using it they would make it available..
Besides its not your daily so what's the hassle..
what's the matter Mcfly, are ya CHICKEN!!
lol I don't mind being the guinea pig. I need an FC Hako + tuning software first though, so I can backup my 98 tune and switch back and forth as needed.
Oh and an ethanol content sensor...just to keep Scotty happy ;)
*Throws frisbee at your hand* Piieww
Lol FC no compatibrrrrr with ethanol'oh contento sensor'oh >_<
$1100 wont get you one that does Flex fuel
The 440 Select that does the flex fuel is $1500
oh yes it will. Read the fine print
"If u buy a HG turbo he will do the 440 select for 1100$.."
I has one and lurve it. ;)
Bit late now though..im sure he doesn't want to fork out another gorilla for tuning
actaully....I bought a G3 years ago....I can has 440 Select for 1100?
Only the R33 plug in ecu for that price if you had a turbo from us. info at:
http://www.skylineecu.com/
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
