This is a SS1 none PU version. It maxes around 250rwkws with same response as a factory turbo, it never worked on this stegea. So I'm happy to have it upgraded to other series at no additional cost.
30rwkw isn't far short, especially considering not many of your customers turbos equal what your test car makes. If you could figure out why it isn't holding boost then I think it would come a lot closer.
No the average of 250rwkws was taken from 3x different cars. they all run up to about 17.5PSI top end, they were 253, 247 and 245. The final afr is all about 12. The best run of 260rwkws was on 23psi.
I couldn't figure out why its not holding boost on his car. I guess its better to exchange for a SS1PU or G2 a G3 which results are well proven by many people.
Or I can exchange with some thing that comes straight out of my car like the G2 I've done for your self and we ended up with same power.
No the average of 250rwkws was taken from 3x different cars. they all run up to about 17.5PSI top end, they were 253, 247 and 245. But the afr is all about 12. The best run of 260rwkws was on 23psi.
I see, but still not far off.
Thing is, what if the turbo isn't the issue? What happens if whatever replacement turbo you send him then doesn't make power? Doesn't look good.
The turbo it self is bit on the small side as it was only made to do a maximum of 250rwkws with factory response, and it was more responsive then a stock turbo. During that time the FNT housings and billet wheels wasn't developed.
Since he's got forged engine, so its no differ to mine, it doesn't hurt to go bigger and bigger is more consistent with power and boost control.
The strangest thing I noticed is we couldn't get it up to 20psi, the higher reading was at 16psi down to 14psi, he said there was a massive heat soak and the timing was just going ridiculous. On e85 he thinks it could make 250.
For the time being I can't afford another tune, my rego is due, so I can't really change the turbo right now. As much as I would love to.
here is my dyno graph from yesterday. The car is a 96 r33 gtst and has the op6 standard hi flow, nismo 555cc injectors, nismo fuel pump, blitz turnflow cooler (heat wrapped pipes), full 3" exhaust and a metal intake. Real happy with the result, thanks Jez!
Edited by Mitcho_7
Looks like a good clean tune, should run really smooth. Can definitely see the difference between the standard highflow and the SS1PU.
Yeh the ss turbo's build boost faster but can't seem to hold it as well uptop. I had one of staos wastegate mods on initially but the boost wouldn't go below 20+ psi...
Edited by Mitcho_7
Glad ur happy Mitch. If i go to shop later i will overlay ur graph with Kasko's and post it up.
Would love to see this as the ss is $700 more expensive.
Question Jez even if mine could hold the 20 psi through the whole rev range it would still be limited by the detonation above 250kw?
Yes it should make more power. Fuel octane is always an issue when trying to push bigger numbers from a smallish turbo, Say if u had a G3 u can run more power with more boost before u hit the knock limit.
I think due to the turbo design being for as best response as possible the top end has to suffer as it chokes up in the rear housing.
That's cool I'm really happy with the response so I don't want to lower that just for a gain in power.
Maybe once I get bored of the power bit I doubt that would happen any time soon.
Even with the clutch still not replaced I managed to break traction all the way to 3rd gear last night.
Let's just say I won
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
