have you/ do you intend to run and atmo bov? If so, go the MAP sensor route.
On a side note, can the adaptronic have duel maps/flex fuel setups?
Edited by Mitcho_7
Yeh. The adaptronic supports flex fuel by interpolation of fuel consumption. That's what the manual said anyway
But not sure about 2 separate maps.
Yep you can setup it to run flex fuel and switch maps.
Could something be restricting my setup do you think guys? Seems odd that's now 2 guys making more power then me on a lot less boost.
I understand different dyno etc etc
But just wondering if anyone has any opinions?
Tis decent compression, maybe look at the cooler like was suggested
Did Jez drop the exhaust at all to see if it was causing a restriction or were you pressed for time?
Edited by Mitcho_7
Finally got mine SS1PU tuned. It made 255rwkws on 16psi. Dame responsive to drive. will upload sheets later when I get a scanner.
nice result mate, congrats
Z32 AFM
3 inch exhaust (decat)
555 injectors
SS1PU
Nistune
3 inch intake
Splitfire coils
Hybrid front mount
Umm have I missed anything
Mine has:
3.5 inch exhaust (decat all the way though)
550c injectors
SS1PU
Adaptronic plugin (Used to have a wolf 3D)
3 inch intake
Splitfire coils
Unknow cooler came with the car.
The best run was 261rwkws when car's cold, and average is 255rwkws after couple of runs. sheet is attached.
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
