Teaser video of my car running again:
Mate was driving and was too nervous to drive it hard, so when I can drive again I'll get some better footage.
Can't watch the video brah
That's an impressive result, Stao. Really holds on up top now. Defo worth the effort of dual actuators IMO.
It made barely any difference Aaron, the dyno result was from two different AR rear housings if I read it right.
Stao, were they 20psi actuators?
We are talking about 1.2psi gain, not a mojor but there is a difference, notice the shape of the curve too. The 20psi actuator still had 3psi drop. this sheet was taken when using the same turbine housing
compare to:
The SS1PU probably had the most boost drop internally gated, this actuator setup should work well with that.
Do you bore out the wastegate hole Stao?
Maybe you could look at the EFR turbos and borrow some ideas from them to come up with a better rear housing design?
The SS1PU due to the higher pressure in the exhaust manifold, too much pressure here would cause heat issues though, you need an exhaust temp sensor in the manifold imo Stao.
Have you incorperated the longer actuator arm for more leverage also?
Ahh crap, I missed that the bottom graph was the two different rears.
Please refer to post 6125. They are identical turbochargers, both with .82 type B rear housings just different actuator setup.
Talk about great service!
I ordered my turbo on Monday, it was built and is already in the post. Stao has still been answering my queries and testing products in between, now that's what I call great service :)
Different arm to mine but looks to be similar length so should have same leverage
Stao mine has the longer arm and I lose 2psi up top. Is it worth loosening the screws and extending it out to the edge of have you tried that and made little difference?
Edited by t_revz
Speaking of restrictions...both my cams look a couple degrees retarded. Might have to grab an adjustable gear for exhaust cam. Obviously need to put a dial gauge on and check for sure but if I see cheap cam gears in Japan next week ill be all over em
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
