so you are changing the compressor cover profile?, if it works you can mod all other G3's for a cost?
i started to fit mine last night, but will take me a month or 2 to do as i am modifying the whole car and only have 3-4hrs
a week to work on it, so if this works im interested
I was confused as in your picture, you have the a comp wheel and housing, and above it is a billet wheel by the looks..
cheers
darren
Edited by jet_r31
Its the profile in the housing. will still be using original cast G3 comp wheel. So the modification can be carried out on any G3s easily (or freely).
The billet wheel was from a SS3 I made a roller version of that as well.
no worries. So do you want as much power as possible out of it or preferably stock response?
i want great response mate. dont forget im rockin an auto so lag will kill me. love it to come on boost early with great midrange.
let me know your thoughts!
Ok I will use same profile that I've done for ssxricho, it will have very similar response to stock while produce more power and torque with a very wide power band.
Dyno reading and reference is at:
http://www.skylinesaustralia.com/forums/topic/261613-hypergear-hiflow-service-continued/page__view__findpost__p__6352727
Results from Ball bearing G3 with updated comp profile:
E85 high mounted externally gated: Maxing out at 365rwkws
VS the older G3:
I've also done one more run with the The ATRSL25.5G. Little bit pissed as I'm missing 1KWs reaching 400rwkws. Maxed out at 399.1rwkws. Need bigger cams for the full potential of this turbo. Still, this is the highest power ever archived on stock cam from Trent's dyno library.
Its actually very fast, the power delivery is so gradual theres hardly any wheel spin. I'm getting some mickey thompson drag tyres and hitting the strip soon.I think this one can get into the 11sec mark
Lol awesome!
Also glad to see an ss1pu trapping good speed! Good work Daniel!
Haha I think it's not a great indication, everyone keeps telling me its an insane mph.
Also that the airport is way way different to the actual drags
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
