some turbo updates:
This is the newer version of the SS2 high flow. I've turned the compressor wheel into the 11 blade design. Probably because the tight packed blades is more effective in trapping air in, it required a lot less wastegate duty cycle (some thing like half) to hold 22psi of boost. So on a internally gated setup it should make a difference in terms of holding steady boost at upper rev range.
  • Like 1
Semi slicks are rubbish for the drag strip, the widewall is much too hard. Good street tyres with lowered pressure will perform way better than semi's on the drag strip from my experience.
Thanks for posting this, I was considering getting semi's for my next trip back to the track & for all round since I don't do many kms. I would've thought they were better too.
Now I guess I'll save up for some 16/17 inch rims and get MT ET streets or something.
No. I don't think he was saying that at all. What he was saying is that semi slicks, in the narrow sense of meaning that we take to be semi-slicks as used on the circuit or street, are crap for drag. MT ETs would not be called a semi slick. They'd be rightly called a drag radial.
Of course he wasn't actually even talking about real semi-slicks, but instead talking about UHP tyres. But seeing as you didn't read properly, you could be excused for thinking that.
Just a quick off topic question, didn't think it was worth starting a new thread for.
I'm going to degree my cams next week sometime just to cross cam timing off the list once and for all, but just want to check if my car will still be driveable on the current tune after any changes? I know MAP sensors are sensitive to changes in the efficiency of the motor, will adjusting cam timing make it unhappy or should it be ok?
some turbo updates:
Have you had it on the dyno yet? Will be interesting to see the results as always :)
it depends how far off they are. if its only a small move it should be fine.. Anything more than 5 degrees and I would be very wary.
I moved my exhaust cam 8 degrees once (accident) and the car ran SUPER lean, had no power what so ever.
I am not expecting it to be out my much if at all, maybe 2 degrees. But gonna do it anyway to cross it off the list. I've got the wideband hooked up so I can keep an eye on mixtures, and if it is out at all then I certainly won't be boosting anywhere until I get a tune. I just wanted to make sure I can drive it to the tuners once it's all setup.
i've recently installed cam gears, advanced intake and retarded exhaust after i found the best settings for response so now turbo hits full boost 500rpms sooner.
that said car barely holds idle and it feels like its leaning out as i'm getting more air sooner so i'd say a tune is needed
Yes no doubt it needs a tune to boost. I'm just talking general driveability, like when I installed the cams the car would be stall on decel because the change in efficiency upset the map based tune.
I just want to know whether my steering and brakes are likely to fail when approaching an intersection again, cos they is something I'd rather avoid repeating :P
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
