Cheers,
Yeh its deceptive..it took me longer to make it "stock/neat looking(and make it all fit), than to jam a hi-mount on it
go have a look at a stock stagea bay..lol
I ended up using a tiny mandrel metal bend from the hydraulic supplier to get over oil drain prob and the o'g
45 degree hose cut in half on the bend and half a straight piece..f**king pain..lol
Its got me pumped to start my next project..4agze/hypergears billet TD06 22G 8cm/E85/30+psi..lol
cheers
darren
Edited by jet_r31
LOL @ 4A project. Gonna keep the supercharger too and make it twin charged ?? ;)
I'm not fussed for stealth on my 200 as its not a daily, but I do appreciate a well presented stealth bay.
superchargers long gone.,, probally no room for it in a Ke10 corolla anyways. Have a nice merge collector mani made up
already , 48mm gate and the hypergear Td06 22G sitting here.
has a W series box in it and hilux diff already, need to do a tilton pedaL setup and all the fiddly crap of the conversion still...
was awesome with 156rwkw, be dangerous with 250+ ..haha
cheers
darren
Heres one for disco,(if he comes in here..) to show you can hide a Gt30 comp cover with ACL shit(especially internal gate), i just bolted it to the 3 standard exhaust mani threads later on
Edited by jet_r31
Pretty sure on mine each tooth is 7.5 degrees.You need to count crank and cam teeth to find out if its the same or search for the answer for Neo's.I highly doubt its different.My intake was about 6 out but only 4 degrees of adjustment left. So I skipped a tooth then rotated the opposite way to get it in the right spot. My head had been skimmed numerous times but yours seems odd its so far out. Looking forward to seeing dyno results :)
Turns out this is what I need to do as well. VCT gear has no adjustment left. Need to skip it a tooth then advance the gear by 3.2 degrees. Trev, did you remark your TDC dimple?
Naa never marked it. I just recorded all results from setting it up and kept for safe keeping.
I actually need to do mine again. I didn't start it for a couple weeks after dialling in and there was a very faint noise audible when I was more than 5 metres from the car. There was the slightest wobble on exh gear. I pulled it off and there was a sliver of dried loctite behind it. Noise disappeared but I haven't redone it.
Will be building a complete new exhaust this week including opening up dump pipe and getting it higher as its now only 75mm from the ground so hopefully I get motivated to dial in again then need a tune with the WMI
Dammit this VCT gear is a pain in the ass to adjust! Having to remove the degree wheel and pointer and timing belt and then reset it all is such a f**k around. Reallyyyyy wish I had bought some adaptor plates when I bought the exhaust gear :/
How did you remove the pulley without removing the belt? I can get the pulley off with the belt on, but it's impossible to get back on. So need to take the belt off, which means removing the degree wheel and moving the pointer.
Ahhh this is getting ridiculous. I'm not getting anywhere. I've just adjusted the gear for the 6th time, but it cancels out. I've advanced it a quarter tooth 4 times, so one whole tooth. Each time the degree values change, but consistently, so I might get 39.5° and 168.5° and then I take it off and adjust it and get 37.5° and 165.5°, meaning I end up back at 116° every time. I don't understand. I've triple checked TDC, I've checked my formula, I've checked the dial indicator. Everything is correct but it's not working :/
Edited by Hanaldo
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
