I think its not a bad result for a auto considering its usually 20kws behind a manual box. What does a locked convert do? I'm thinking of working out my Kia's auto.
its not a bad result, before we used wmi, it made 258rwkw, and at that time they said they have done 5 3076 56T .82 setups
on stageas and that the good ones got into the 250's on same boost and all 5 where out of puff the same, even the ones they owned personally... i woudn't run that timing though, id pull 2 degrees out if it was a 98 tune, and it was on the knife edge
In all truth, the wmi let me run 12 degrees more timing when you take that into account...lol
..theres a few thing i can check, and a few things that happened that i'll keep to myself and see if the theorys workout,I'll revisit the dyno in a month or so one night.
Im happy with the turbo and everything, just want to make sure its all working as well as it can
cheers
darren
converter locked, not letting cool down really, 2 massive transcoolers, one has a thermo, total overkill..lol
yeh its fast,it would be deceptively quick but even my mates vl that runs 10.3@133 doesn't feel quick to me either, thats linear to in its delivery
my mates brother has a car that we use for a guidepost..R34 270rwkw on 17-18psi, 12.00@117mph. ill see how it goes against that, my mates 338rwkw stagea flogs it
cheers
darren
Hey Daz was actually looking at that r34s dyno sheet when we got back from the dynoing your stag, it has a very progressive curve makes 281rwkw on 21 psi . It's also more sluggish in spool than yours .
Yes the atr28g4 is a of a .64 ended t25 turbine housing and that makes 300rwkws on a ca18det. Just abit laggy.
haha..my bad, thats a huge bitch. And i wasn't thinking. I meant to say a Ca18 T25 housing, the .48 ones
Something that would fit in that housing, but give greater flow than standard turbo and good response still
for a 1.5L non crossflow motor on 20-25psi..talking 150-170rwkw. i guess.
Be good if it could still bolt in a .64 housing later for testing purposes
Something that would make 210rwkw ish on a sr20 on 98 with best response may be in the ballpark ish
even a standard Sr20 T28 would be decent, just wondered if you had something better..
cheers
darren
Just installed my hiflow atr28g2 with new .64 rear housing and fnt mod on my sr20det
Feels more responsive already untuned than my td05h18g and its only on 1bar for now till I get it tuned in a few weeks
Giving it 3/4 throttle comes on quite smoothly from 3500rpm on where as my previous turbo had nothing till after 4000rpm also has a slight whistle to it as it boosting up from 2000rpm on.
Is this normal as it has fnt ?
Sound very similar to the semi trailer trucks
Hoping its makes similar power that I had before but better response previously had 264rwkw with a td05g18g 24psi dropping to 21psi by 4000rpm on eflex
I'm going to run 22psi response wise I can feel its definately going to be better just hoping it makes the power
Could be induction sound?Just make sure it has plenty of clean oil supply and none restrictive oil feeding line, it should be fine. Make sure it has 3inch free flow induction and exhaust before going to the dyno. Preload actuator as you go if more boost is required.
or hks 2530 type sizing , but fitted in .48 housing..
cheers
darren
Darren just buy my HKS 2535.no more lag than a 2530. And on a ca18det would be crazy fun alround. Comes with dump oil water lines. $950ono. .64 rear. I had one on my s13 ca18det 8-9 years ago and was mental fun. Done 15,000km in 5-6yrs, bought néw from created in Melbourne. Just a thought. Perfect condition. Come off my r33. It's still on there matter a fact. Could even put it in the .48 housing as you mentioned above and sell the HKS rear. ???
But I'd leave .64 cos.48 would choke it wouldn't it Darren ?? Anyway just a offer mate. Sorry to pinch the thread. ;)
Cheers Josh.
Edited by Joshbigt62r
Cheers Josh.
lol, its not for a ca18, and i have used a hks 2530 on these motors 12ish yrs ago..was just wondering what stao had. its not for me, i just sold a mint 2530 for $600 last month as i had it sitting in a box for 7 yrs
cheers
'darren
Edited by jet_r31
Also depending on the compression ratio of the motor its going to fit. For a modern 10.5 : 1 motor, a slightly larger turbine end is helpful on stopping it from pining on higher boost level. Like a 1.5L engine on that sort of compression ratio should be pretty responsive with a .64 turbine end with a 68mm compressor if the goal is about 24psi.
no stao, 8.5.1 comp, 2 valve , non crossflow, poor flowing head toyota k motor head.
can you fit a larger turbine than standard T28 spec stuff in the .48 T25 housing out of interest?
cheers
darren
yes I have made couple of turbine wheels that goes into the T28's bearing housings. This is mine personal CA18det turbocharger out of my Sil180 few years ago. I've made this after been defected to pass EPA with (it worked). lol
It has a small 52 76mm comp wheel with a massive 65mm turbine.
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
