Also better pics of the dyno graph:
Green is my old setup: stock engine + china manifold
Blue: Is the forged ported engine + Brae manifold
Everything else is the same
Its a normal intercooler just the attached piping is return flow
Sort like this pic I found on google
So if Scotty where to fix up some of the bends it might be better lol?
As im going to assume its the angle of the bends not the length of the pipe that might be the restriction?
Is hybrid intercoolers any good? Dont know much about them
Personally I highly doubt it has anything to do with the bend causing restriction. Mine was a pretty fkn brutal bend as well as being 2.5" piping and didn't have any issues flowing 295rwkw.
Interesting!
Though 284rwkw and 295rwkw isn't much difference lol
Have there actually been results with these turbos on an RB25 making more power on straight pump gas? I've made noises about the wondering how the VNT/FNT technology would perform on pump gas when being leaned on - partly because I am curious about how exhaust manifold pressure is going to behave with what could be defined as obstructions along the flow path towards the turbine. E85 can mask some effects of soaring pressure (ie, being much more knock resistant) but with pump gas it is going to start complaining quite quickly if it is a bit excessive.
The principle behind VNT could easily be thought of as being equivalent to being variable A/R in regards to it's effect, and relies heavily on correct actuation to not become a restriction at the wrong point and also providing good spool - however how FNT has had me fascinated is that surely there is the potential that it has the net effect of providing a larger a/r that flows (and spools) like a smaller one, to some degree defeating the purpose?
I have been specifically waiting for pump gas results to see how these go and this is the first FNT I have noticed being leaned on using pump gas and the result is what I would have expected with "nozzles" angled to boost spool which don't adjust once flow requirements increase. There may be results for this setup which prove that it is fine, so I am absolutely by no means suggesting that I believe there would be an issue with it - I am just voicing an idea which hopefully can easily be proven wrong to eliminate, or otherwise provide a possible explanation.
Interesting!
That's true, though it was at ~17psi and the tuner said it still had more but he stopped there because it's a standard engine (read: he's a big softy sooky-lala)
Stao was originally doing all his testing on pump 98 man. All the FNT gear was originally produced with pump 98, and he didn't have an issue. There are a tonne of 98 based FNT results (from Stao's test car, same tuner same dyno) in the dyno thread.
See below hekkas MS Paint representation of what my bend looked like. Yes, the piping didn't even make 90 degrees before meeting the next part of the bend.
Thought that could be the case - any examples out of curiosity? I did a search for "FNT" and the only result that came up for me was Hanaldo's which I have the impression the entire setup has never quite delivered for him, yet?
One thing I forgot to mention
With the new engine, Trent had to take out 8 degrees of timing compared to the old engine, as any more it would be pinging too much.
Fuel used was BP 98. Filled up only a couple days before hand
Almost all results pre page 43 on the dyno thread is on 98 ron, bar like 2 posts max.. Once Stao went to E85 he never wen't back.
To my understanding the turbine side of things reached a point where no changes were needed beyond housings and compressors. Thus he did a back to back with the SS2 when he went to E85 and any advancement from there can be seen as an improvement regardless of what fuel you are running.
Here is page 43 where he first changed to the current full blade SS2 on 98, that is an FNT IWG item and went 312kw:
http://www.skylinesaustralia.com/forums/topic/55845-rb25-turbo-upgrade-all-dyno-results/page-43
I am fairly sure the 312kw item is the new version.
Old version is the high/low blade 71mm compressor, like what can be found in my SS1PU. Fairly high tip height with familiar looking blade curvature.
New version Stao played with the 'full blade' design and found it to work quite well. Full blade SS2 is 74mm.
So in theory the new one may be higher flowing? Here's Stao's post that made me think the 312kw was an old version http://www.skylinesaustralia.com/forums/index.php?/topic/261613-Hypergear-Hiflow-Service-Continued.#entry6948624
In the 312 result he noted it as being a prototype, which I am sure was the move to the full blade wheel. However, the older SS2 was also 300kw capable.
Time for Stao to chime in and clarify now lol
This is the result from the latest SS2 FNT model on pump 98, stock manifolds, internally gated as previous posted. The older version is no longer manufactured.
I had a quick chat with Trent (tuner) about With Blah_blah's result. Apparently he pulled 8 degrees of timing out of his old map, as it some how knocked badly. Meanwhile the stock engine did not have this issue using the same turbocharger and the rest of the setup.
Reasons given by his engine builder was that because the head ports are now over sized so they flow much more then what they were standard. And the extra flow now demands for a larger rear housing. I personally do not have any experience with ported heads so I can't comment.
Well, bigger rear end is not a problem, I have them in 1.02 rear or .82 turbine housing with a bigger G4 turbine wheel.
Hmm interesting - if it were enough porting to cause that effect then that potentially means too much porting, I'd have thought! Its not miles behind in power for 8deg less timing though, at least?
It may not even be the rear housing it may be the turbo altogether is a bad match now...I mean you design your turbos to match a rb25s power zone...that is 3500-6500....he has now designed a head that is probably more suited to flow from 4000-8000 so a bigger turbo all together may be what's in order..
Will the ss2 even spin to 8k or will it drop off power too early?
    • This is for an RB20DET. Sorry for not including that.
    • Welp, this is where my compression lands after my rebuild. Thoughts? I have ~6 hours on the motor.
    • Well, after the full circus this week (new gearbag, 14 psi actuator on, injectors and AFM upgraded, and.....turbo repair) the diagnosis on the wastegate is in. It was broken. It was broken in a really strange way. The weld that holds the lever arm onto the wastegate flapper shaft broke. Broke completely, but broke in such a way that it could go back together in the "correct" position, or it could rearrange itself somewhere else along the fracture plane and sit with the flapper not parallel to the lever. So, who knows how and when exactly what happened? No-one will ever know. Was it broken like this the first time it spat the circlip and wedged itself deep into the dump? Or was it only broken when I tried to pry it back into place? (I didn't try that hard, but who knows?). Or did it break first? Or did it break between the first and second event of wierdness? Meh. It doesn't matter now. It is welded back together. And it is now held closed by a 14 psi actuator, so...the car has been tuned with the supporting mods (and the order of operations there is that the supporting mods and dyno needed to be able to be done first before adding boost, because it was pinging on <<14 psi with the new turbo with only a 6 psi actuator). And then tuned up a bit, and with the boost controller turned off throughout that process. So it was only running WG pressure and so only hit about 15-16 psi. The turbo is still ever so slightly lazier than might be preferred - like it is still a bit on the big side for the engine. I haven't tested it on the road properly in any way - just driven it around in traffic for a half hour or so. But it is like chalk and cheese compared to what it was. Between dyno numbers and driving feedback: It makes 100 kW at 3k rpm, which is OK, could be better. That's stock 2JZ territory, or RB20 with G series 550. It actually starts building boost from 2k, which is certainly better than it did recently (with all the WG flapper bullshit). Although it's hard to remember what it was like prior to all that - it certainly seems much, much better. And that makes sense, given the WG was probably starting to blow open at anything above about 3 psi anyway (with the 6 psi actuator). It doesn't really get to "full boost" (say 16 psi) until >>4k rpm. I am hopeful that this is a feature of the lack of boost controller keeping boost pressure off the actuator, because it was turned off for the dyno and off for the drives afterward. There's more to be found here, I'm sure. It made 230 rwkW at not a lot more than 6k and held it to over 7k, so there seems to be plenty of potential to get it up to 250-260rwkW with 18 psi or so, which would be a decent effort, considering the stock sized turbo inlet pipework and AFM, and the return flow cooler. According to Tao, those things should definitely put a bit of a limit on it by that sort of number. I must stress that I have not opened the throttle 100% on the road yet - well, at least not 100% and allowed it to wind all the way up. It'll have to wait until some reasonable opportunity. I'm quite looking forward to that - it feels massively better than it has in a loooong time. It's back to its old self, plus about 20% extra powers over the best it ever did before. I'm going to get the boost controller set up to maximise spool and settle at no more than ~17 psi (for now) and then go back on the dyno to see what we can squeeze out of it. There is other interesting news too. I put together a replacement tube to fit the R35 AFM in the stock location. This is the first time the tuner has worked with one, because anyone else he has tuned for has gone from Z32 territory to aftermarket ECU. No-one has ever wanted to stay Nistuned and do what I've done. Anyway, his feedback is that the R35 AFM is super super super responsive. Tiny little changes in throttle position or load turn up immediately as a cell change on the maps. Way, way more responsive than any of the old skool AFMs. Makes it quite diffifult to tune as you have to stay right on top of that so you don't wander off the cell you wanted to tune. But it certainly seems to help with real world throttle response. That's hard to separate from all the other things that changed, but the "pedal feel" is certainly crisp.
    • I'm a bit confused by this post, so I'll address the bit I understand lol.  Use an air compressor and blow away the guide coat sanding residue. All the better if you have a moisture trap for your compressor. You'd want to do this a few times as you sand the area, you wouldn't for example sand the entire area till you think its perfect and then 'confirm' that is it by blowing away the guide coat residue.  Sand the area, blow away the guide coat residue, inspect the panel, back to sanding... rinse and repeat.
