Hi every one I'm back to business. The Kia project in China is completed but disappointed in the way of how it has been organized, some of you might already seen my update on Facebook.
Updating with some video footages from xxxRicho's R33 running the latest R33 turbo high flow with 294rwkws (E85) at
Motul ADVAN World Time Attack 2013 Club Sprint ending in 5th
Have any of you guys used the Kando oil/water line kit to fit up your SS1/SS2 turbos?
They state this is made for the stock turbo in the stock location.
Link:
http://www.ebay.com.au/itm/Turbo-Oil-Water-Line-Stock-T3-Nissan-Skyline-RB25DET-6AN-/271306380797?pt=AU_Car_Parts_Accessories&hash=item3f2b1ed5fd&_uhb=1
Used Kando lines on my low mount standard manifold IWG SS2. Fits perfectly.
sex, thanks Josh will order now :)
Stao was a little hesitant on saying if it fits (fair enough)
Am also using Kando lines with my SS1PU on my SR20.
I simply used the banjo Stao provided and screwed the -4AN kando line onto that. The rest work a treat!
  • Like 1
Yea true.
Some updates on the new SS1PU turbocharger prototype that is due for trailing very soon. So basically I still want the current SS1PU's response but with a lot more power. Well here it is:
What are the changes Stao?
I was thinking the turbine on your current highflow seems to be of made of stardust or something, and was wondering if that technology can be carried over the the SS1PU?
I flat out think a 2IU highflow on my SR would be crazy.. I'm so tempted to try.
The compressor is the newer gen 11 blade SS compressor I'm sure. They are all using that now.
But I notice Stao is actually using his T3 5 bolt rear housing, so that means the bearing case and turbine wheel are no longer the GT28 sized item.
Stao I am SERIOUSLY interested in this turbo... It may complement my T3 highmount setup I have lurking in the garage. Please share results ASAP!
Damn, you take a very impressive photo of a turbo haha..
Really considering getting a new turbo soon, as I am already sick of the t04e.. And think the seals are starting to leak a little.
Also not very good on the street, I know you said an sspu1.5 but that was a while back and maybe things have changed a little with the way there improved.
For an rb20det. I'm at 171kw and don't see and boost until about 4,400-4,600rmp.
Anything over 200kw and a little more responsive and I'll be stoked :)
Yellow jackets, Z32 afm & yellow jackets are also ready to go in when I have enough for a hypergear turbo + tune
This is a new turbine side design for a Rb25det it is different to whats in the standard high flows, I really want it to make more power with better response as if possible.
hy_rpm: I did make a 11 blade 60mm compressor wheel for the SR20det motors as well as a 64mm and a 68mm wheel. I believe the maximum that a SS1PU turbine can perform on a SR20det would be towards 250rwkws with cams on pump 98, so those are really targeting at the responsive end.
ZRBE: As for the RB20det my recommendation would be the 64mm billet SS1 turbocharger. it has similar response to a 2530 with abit more power.
  • Like 1
We will stick to the original plan and I'll be using e85 so high boost 25psi
You suggested to try a ss1.5 fnt .86ar due to high boost and s14 comp housing so will be bolt on and go from there
260-270rwkw should be achievable if the turbine is capable of 250rwkw on pump 98
As pump usually caps the boost to 20psi as more than that is pushing it due to pinging and heat but e85 allows me to run 5psi more boost which should net me 25kw we see
Thanks
Also that's what I was after similar power and response to the hks2530 as that was my last turbo setup on my sr20det and I was happy with that it made 250rwkw on 22psi dropping 19psi on eflex full boost by 3400rpm
I was happy and wouldn't have changed it but the bearings got noisy in it
So would I be better with the .64 or with struggle with 25psi as that's what the 2530 had
Depending on whats struggling. At that boost level it could be the compressor or the turbine, I think its more of the compressor end. I've pmed you with some recommendations if you would like to trail them out. I'll be happy modifying them free to reach your performance target.
+1 for the above - He really will.
Is that new thing suitable for, I dunno, some guy wanting to run a low mount smallish turbo at 28psi on a RB28 auto sedan? ;)
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
