if you hold down the mode button on mode 1 2 3 & 4 is the gain 20 all the way through them? you can set it differently for each mode by holding down the mode button for three seconds then adjusting with the select button.
Yes, Gain is 20 all the way through channels 1 to 4.
If you are using a Mac solenoid for boost control. I'm not if this EBC allow different gain settings at different RPMS which some ECU support. You can can use perhaps 50% gain down low and 100% gain after 5000. But either way the SS2 should have a slight creeping behavior working with a EBC, I think the drop could be related to insufficient supply of air or discharge of hot air inside the exhaust. See if boost level changes after 5000RPMs without air box lid and mesh filter first, then try a hollow cat ( I can lend u one if you need ).
This is a newer high flow profile available for Rb20det owners. It is very specifically aimed at response. The profile configuration works out very close to a 2871 in 52T. Maximum power wise would be expected around the 230rwkws mark depending on supporting mods and amount of boost given.
Just to correct some mis-information i gave...the gain is the same all the way through because you can't set it individually for each mode. each setup is different but i've found a gain of 30 and setting of 60 to work well to 1.18bar or if i want a different response i set gain to 7 and setting to 71 which gives me 1.18-1.2 bar.
Thanks man. Yes I thought it might be the case that there's only one global gain setting. So mine is currently at setting 55 and gain 20 and peaks at around 1.35 bar.
I feel that the tuner has a good job given the constraints of the EBC. The next thing I'll investigate is the possible restriction in the exhaust (cat) or intake (airbox, IC).
Best to upgrade induction and exhaust first then play with the EBC as the end result will vary.
I'm posting up an promotion on our new ATR43SS-2 internally gated bolton turbochargers so more people can enjoy our latest development. The Retail price on this item is currently $1450, you can have own them now for $999 including braided oil feeding line. The Special offer is for 20 units only. That is currently the best performing RB25det bolton turbocharger.
Product details and Dyno results are:
http://www.hypergearturbos.com/index.php?route=product/product&path=72&product_id=81
  • Like 3
This is the larger version of the 2nd generation SS2. It is 1.5mm bigger on compressor side and 3mms larger on turbine side. More power. :woot:
On the less complicated to build turbochargers. Since we have found good uses of a CNC machine that we can rent, we will be making TD06L2 based turbochargers are a very cheap price. that will be the SLSS2 and Sl20.5G turbochargers. Will update new pricing and details shortly.
I thought you had your own CNC machine? I thought that was how you make the billet compressors?
For the quantity that I'm currently doing its not worth to own. Also its only worth while using CNC making a number of identical housings at once, which in my case its different combinations for different customers. So most of the housings are still hand made on lathe on milling machine.
The SS wheels are originally just a machined version of the cast wheel, trailed and modified through time by my self. The CNC programming was done by an engineer that I hire, I also hire and work with many other engineers for different purposes on the development and manufacturing of a turbocharger.
Other thing worth mention is the CNC machine that does the profiling and machining of the comp and turbine housings are not the 5 axis machine that does the billet wheels. Those are CNC lathe and mills. One does all the machining of the horizontal profile and groves, and the other one does all the drilling and tapping of the holes. In which the Greedy comp and turbine housings that are made to run on C clip and V clamps are cheaper and quicker to produce as all aspects of machinery was done on one horizontal CNC lathe.
Can't machine a cast wheel, material is too soft. it starts as a copy of the cast wheel, which is a Billet comp wheel that is identical to a normal cast wheel, I then took it for a dyno run for a base output.
From there I modify the wheel blade shapes, tips, height, hub sizes and etc then evaluate each and single modification done to see what sort of differences it has made compare to base output on a dyno. Drawing of the better performing wheel where sent to produce in a batch. Like I've mentioned, my Skyline have done 1807 dyno runs since the start of this project, and probably made this thread containing more dyno readings then the dynosheet section plus a lot more that wasn't posted.
    • I'd be worried about having to parallel park a boat like that. Magnificent car though.
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
