Result from R33 21U high flowed turbocharger:
R34 GTT RB25DET NEO unopened engine.
- Power FC
- 1000CC ID injectors
- Factory cams, cams gears, and all manifolds.
- HyperGear R33 GTST 21U OEM High flowed turbocharger
- 3 inches turbo back exhaust
- Walbro 470L/H Fuel pump
- 4 inches induction pipe
- Split fire coil packs
- 600x300x76mm front mount cooler
- Tuned by Trent Hewitson, Chequered Tuning.
312rwkws @ 19psi E85 fuel
Imagine if they could maintain that initial smooth steep power curve increase as the boost comes on haha
Stao, do you do the option to supply the rears ceramic coated once ordered?
I don't have the machine to do that. There is a workshop not far away that does ceramic coating, I think they charge around $100 a housing.
Another result to post. ATR43SS2 externally gated. This is the older version.
Usual 3 inches induction and exhaust, FMIC 600x300x75, 1000cc injectors, high mount, 45mm external gate, PFC E85 fue.
<script pagespeed_no_defer="">(function(){var g=this,h=function(b,d){var a=b.split("."),c=g;a[0]in c||!c.execScript||c.execScript("var "+a[0]);for(var e;a.length&&(e=a.shift());)a.length||void 0===d?c[e]?c=c[e]:c=c[e]={}:c[e]=d};var l=function(b){var d=b.length;if(0=d.offsetWidth&&0>=d.offsetHeight)a=!1;else{c=d.getBoundingClientRect();var f=document.body;a=c.top+("pageYOffset"in window?window.pageYOffset:(document.documentElement||f.parentNode||f).scrollTop);c=c.left+("pageXOffset"in window?window.pageXOffset:(document.documentElement||f.parentNode||f).scrollLeft);f=a.toString()+","+c;b.b.hasOwnProperty(f)?a=!1:(b.b[f]=!0,a=a<=b.e.height&&c<=b.e.width)}a&&(b.a.push(e),b.d[e]=!0)};p.prototype.checkImageForCriticality=function(b){b.getBoundingClientRect&&q(this,b)};h("pagespeed.CriticalImages.checkImageForCriticality",function(b){n.checkImageForCriticality(b)});h("pagespeed.CriticalImages.checkCriticalImages",function(){r(n)});var r=function(b){b.b={};for(var d=["IMG","INPUT"],a=[],c=0;c=a.length+e.length&&(a+=e)}b.g&&(e="&rd="+encodeURIComponent(JSON.stringify(s())),131072>=a.length+e.length&&(a+=e),d=!0);t=a;if(d){c=b.f;b=b.h;var f;if(window.XMLHttpRequest)f=new XMLHttpRequest;else if(window.ActiveXObject)try{f=new ActiveXObject("Msxml2.XMLHTTP")}catch(k){try{f=new ActiveXObject("Microsoft.XMLHTTP")}catch(u){}}f&&(f.open("POST",c+(-1==c.indexOf("?")?"?":"&")+"url="+encodeURIComponent(b)),f.setRequestHeader("Content-Type","application/x-www-form-urlencoded"),f.send(a))}}},s=function(){var b={},d=document.getElementsByTagName("IMG");if(0==d.length)return{};var a=d[0];if(!("naturalWidth"in a&&"naturalHeight"in a))return{};for(var c=0;a=d[c];++c){var e=a.getAttribute("pagespeed_url_hash");e&&(!(e in b)&&0=b[e].k&&a.height>=b[e].j)&&(b[e]={rw:a.width,rh:a.height,ow:a.naturalWidth,oh:a.naturalHeight})}return b},t="";h("pagespeed.CriticalImages.getBeaconData",function(){return t});h("pagespeed.CriticalImages.Run",function(b,d,a,c,e,f){var k=new p(b,d,a,e,f);n=k;c&&m(function(){window.setTimeout(function(){r(k)},0)})});})();pagespeed.CriticalImages.Run('/ngx_pagespeed_beacon','http://www.sau.com.au/forums/index.php?s=b9c74eaa9e8468f815fb75ce17859f73&app=forums&module=ajax§ion=topics&do=quote&t=261613&p=7654228&md5check=b49b7836ac70550ba950be58aabf0e55&isRte=1,6YgIICLrb3,true,false,Xk_isDeHn4U');</script>power.JPG&&0){for(var>
Hey Tao, its actually got 4inch intake, 4inch striaght through exhaust, 600x300x100mm cooler,50mm gate
Stao, How do you work it so the aircon drain pipe doesn't sit against the dump pipe? The flange on the rear of the turbo is so huge it pushes it all back and its melted my aircon drain pipe.
Any videos boostn looks brutal on paper what size dump pipe
Yeah was about to put a couple up now for you to see, the combo works really well, dump is 3 inch. Will put the link up soon when I get on the comp.
That would be awesome do you think the 3" dump could be bit of a restriction
With a 50mm gate to atmo I dont think its a restriction but if was plumped back then would be.
here are a couple of vids
https://www.facebook.com/video.php?v=10204787985648996&pnref=story
https://www.facebook.com/#!/video.php?v=10204742413869730&pnref=story
Edited by boostn0199
Checked them vids out very cool it comes on supper early real nice setup would love to have that response you have there.
Are u running metal hg and studs ?
Just a stock headgasket and std headbolts.
Stao.
Sorry if you've covered this already.
So you can get either the standard high flow for $850 with the line etc or the new model highfliow for $990 (the extra cost covers different internals and a high pressure actuator?)
So the r33 high flow on an r34 should do up to around 310rwkw with the right mods,
With E85 and Greddy return flow cooler what do you think it will max out at?
To put the non return flow cooler in did you have to cut out part of the battery tray (and cut the hole)?
Big responsive numbers from the high flow. Would like the response it offers
Good day, Yes the new actuator opens the waste gate bunk to 90 degrees. Which is included in the $990 option.
You will need E85 to get 310rwkws using a R33 high flow on a R34.
I'm usually seeing around 245rwkws with the return flow cooler, on E85 it is expected to reach 270rwkws.
To use PWR cooler or some thing in a 100mm front mount, you do need to cut under the battery tray.
    • Yeap, all the NC's that I originally looked at that had a hard top were PRHT, which makes the roof line look horrible, hence why I said nope to them My only caveat for another MX5 was it needed to have a hard top, and initially I didn't think you could get a detachable hard top for the NC,  like my NB had Again, a big thanks to Matty for helping me source the detachable hard top for my little girl, they are as rare as hens teeth in Australia, and the few people who have them, keep them Also to Greg, for initially pointing me in the NC direction NC PRHT 🤢🤮 Not mine (I really should take more photos of my car), but a NC with the detachable hard top 😁 To me, the difference in how the detachable hard top roof line looks, and how it actually follows the bodies lines, like they do on NA's and NB's, is chalk and cheese compared to the bulbous looking PRHT
    • Haha good old Letterkenny! If you're looking for another great english canadian comedy, I strongly recommend Trailer Park Boys.
    • I live in a French European province, within a very metric country. We hate football here and the statue of liberty was actually built in France haha. Sadly, we're currently also feuding hard with the US due to tariffs. The US is the US. Everywhere else, is everywhere else.
    • Heater wasn’t working in my 32  so I decided to pull my dash out ( sounded like a great idea at the time) so initially I was sure the heater core was blocked. When I pulled it out turns out that the heater blower actuator was cable tied so it stayed shut and this prevented the heater core from doing its job as well as flowing. so currently the dash is out the heater core is out and seems to be fine but I think I’m in over my head  and need someone that knows what they are doing to take over and get it finished. I’m located in mt Annan, nsw 2567 if anyone has any ideas or suggestions please let me know
