Most i seen was 266kw from my car 25psi dropping e85 and that was with the larger rear housing .86
Stock bottom end sr but
I would reccomend going the atr28ss2 in bb with .64 rear housing more responsive due to the smaller rear and i made 280kw with this
On a built motor with larger cams and custom exhaust manifold i would see it making 300kw
Action Dan: Yes. the factory exhaust manifold is a restriction and SR needs cams to make power. Plus your usual free flow FMIC, induction and exhaust.
Ask tao im sure he can arrange that
Most results ar from rbs but usually all in by 4000rpm and there only running t3 single scroll
Twinscroll will help alot hence why evos get away with 300kw turbos but are still responsive
This particular SR20det engine is something built by forcedmotor works 4 years ago. It run one of our ATR45SAT turbo compete and won WTAC Open class in 2016 and is still a current world record holder of the fastest SR on Wakefield. Its on a single T3 scroll manifold running external gate, and that pumped 400rwkws on E85 fuel, 28psi by 4250RPM. Far as I know its just a standard rebuild, no VCT with forged pistons with 264  / 256 Tomei Pro cams. For around 350rwkws mark I will be recommending this turbocharger.
  • 3 weeks later...
Some results to share, This time is from Justin's drift car running with one of our ATR45SAT ceramic ball bearing turbocharger.
R33 GTST unopened engine.
HyperGear Atr45SAT Ceramic ball bearing turbo
6 boost manifold
Turbosmart 45mm Gate
Ebay 600x300x100 Cooler
ID 1000cc Injectors
460 lph Fuel Pump
3 inches turbo back exhaust
Haltech ECU
E85 fuel
Car made 397rwkws @ 21psi on a conservative tune for stock engine. Should see 420rwkws at full potential.
I would high flow the factory turbocharger using a ball bearing core with a G2 or a SS15 profiled wheel sets. the SS15 is a better choice for power and response.
For the best result use an Rb25det turbo. For a Ball bearing, billet wheel Ss15 profiled highflow looking at $1500 to complete including oil line.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
