See you make a version of the g25-550 and. 660 aswell. Do you have any test of the smaller turbos on the rb25det for us that not hunt big power but whant a good responsive setup for a unopende engine? Looking for a good upgrade for my rb25 powered Datsun 260z. Whant something around the 350-400whp mark. And dont whant a high flow.
Best regards Stian
Best regards Stian
Hi I found G25 turbine is too small for a Rb25det motor. I recommend our ATR43SS-2 in T3 .71 turbine, its very similar to a G30-660 with better response. Its supplied as a brand new turbo internally wastgated.
  • Thanks 1
How many kws can you see out of it?
Assume the application is for internal gate.
Far as internal gate concern SS-2 makes around 300rwkws on P98 fuel in either .63 or .71 turbine housing. Response are about the same between the two.
  • Like 1
Can you link me to the correct one on your site?
.71 P98 definitely hit 300kws without being to laggy?
Yes correct. Link is at:
https://hypergearturbos.com/product/atr43ssiwg/
SS2 Profile, T3 .71 Turbine housing, Ball bearing upgrade, and oil line kit. Thats pretty much it.
Edited by hypergear
  • Like 1
Thank you. Was going for a Pulsar g25or30/660 but then i will look at this. 👍
Quick spool up and respons is the main thing in this can aswell as the sweet sound of the g-series turboes.
Hard time to find ppl using in the size cus every one that post dynos is almost only big power.
Dont know if i can manage to fit a new exhaust manifold this year or if i have to use the stock the first year.
  • 4 weeks later...
How much more power and lag does the ss3 make?
SS3 has very similar to a SS2. It needs to be externally gated for boost control. Performance wise about 60kws more in comparison.
Edited by hypergear
  • Thanks 1
Thank you, damn want to stay internal. Just have to replace with forged pistons and rods now. So was going for a few more kws
  • 3 weeks later...
How much difference going internal to externally gated?
  • 3 weeks later...
ATR43SS-1 is better suited for a RB20det engine. SS-2 is suited for a Rb25det engine. Externally gated kit is highly recommended as it makes more power on less boost pressure with higher power ceiling. I've attached an example of our high flowed OP6 turbocharger running both internal and external gate.  Turbo is boosted to a point that no more power could be made. Car's an R33 with built Rb25det engine.
The SS-2 made 317rwkws V 21U G3 high flowed made 282rwkws at a point that no more power could be made on a built RB25det Neo motor on P98 / Ron 93 fuel. 21U high flow is about 400RPM more responsive making 20psi by 3600RPM, while SS2 made 20psi by 3800RPM.  High flowed Rb25det turbo drives very similar to stock turbo.
My recommendation is still ATR43SS-2 in T3 .71 rear housing with ball bearing core, as it has stronger power delivery with higher power capacity.
  • Thanks 1
  • 2 months later...
We've been working on all sort of different types of turbos with majority of work load shifting towards Euros in the last few years. The Skylines are more of a hobbie then a daily, at least its like that in Australia. I will update photos from some of our latest RB jobs. Whats recent is G30 turbine housing externally gated plumb back kit using T3 .83 geninue housing. It can be made to suit G35, G40 and G42 units. External gate optional.
Edited by hypergear
  • Like 4
That's great news
Skyline scene is a bit odd (yes I've been following that particular Facebook page), and most of the owners are young boys with no money.
I thought that the high flowed rb25det turbos were a lot more responsive than the stock one? Would that mean better low end torque?
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
