See you make a version of the g25-550 and. 660 aswell. Do you have any test of the smaller turbos on the rb25det for us that not hunt big power but whant a good responsive setup for a unopende engine? Looking for a good upgrade for my rb25 powered Datsun 260z. Whant something around the 350-400whp mark. And dont whant a high flow.
Best regards Stian
Best regards Stian
Hi I found G25 turbine is too small for a Rb25det motor. I recommend our ATR43SS-2 in T3 .71 turbine, its very similar to a G30-660 with better response. Its supplied as a brand new turbo internally wastgated.
  • Thanks 1
How many kws can you see out of it?
Assume the application is for internal gate.
Far as internal gate concern SS-2 makes around 300rwkws on P98 fuel in either .63 or .71 turbine housing. Response are about the same between the two.
  • Like 1
Can you link me to the correct one on your site?
.71 P98 definitely hit 300kws without being to laggy?
Yes correct. Link is at:
https://hypergearturbos.com/product/atr43ssiwg/
SS2 Profile, T3 .71 Turbine housing, Ball bearing upgrade, and oil line kit. Thats pretty much it.
Edited by hypergear
  • Like 1
Thank you. Was going for a Pulsar g25or30/660 but then i will look at this. 👍
Quick spool up and respons is the main thing in this can aswell as the sweet sound of the g-series turboes.
Hard time to find ppl using in the size cus every one that post dynos is almost only big power.
Dont know if i can manage to fit a new exhaust manifold this year or if i have to use the stock the first year.
  • 4 weeks later...
How much more power and lag does the ss3 make?
SS3 has very similar to a SS2. It needs to be externally gated for boost control. Performance wise about 60kws more in comparison.
Edited by hypergear
  • Thanks 1
Thank you, damn want to stay internal. Just have to replace with forged pistons and rods now. So was going for a few more kws
  • 3 weeks later...
How much difference going internal to externally gated?
  • 3 weeks later...
ATR43SS-1 is better suited for a RB20det engine. SS-2 is suited for a Rb25det engine. Externally gated kit is highly recommended as it makes more power on less boost pressure with higher power ceiling. I've attached an example of our high flowed OP6 turbocharger running both internal and external gate.  Turbo is boosted to a point that no more power could be made. Car's an R33 with built Rb25det engine.
The SS-2 made 317rwkws V 21U G3 high flowed made 282rwkws at a point that no more power could be made on a built RB25det Neo motor on P98 / Ron 93 fuel. 21U high flow is about 400RPM more responsive making 20psi by 3600RPM, while SS2 made 20psi by 3800RPM.  High flowed Rb25det turbo drives very similar to stock turbo.
My recommendation is still ATR43SS-2 in T3 .71 rear housing with ball bearing core, as it has stronger power delivery with higher power capacity.
  • Thanks 1
  • 2 months later...
We've been working on all sort of different types of turbos with majority of work load shifting towards Euros in the last few years. The Skylines are more of a hobbie then a daily, at least its like that in Australia. I will update photos from some of our latest RB jobs. Whats recent is G30 turbine housing externally gated plumb back kit using T3 .83 geninue housing. It can be made to suit G35, G40 and G42 units. External gate optional.
Edited by hypergear
  • Like 4
That's great news
Skyline scene is a bit odd (yes I've been following that particular Facebook page), and most of the owners are young boys with no money.
I thought that the high flowed rb25det turbos were a lot more responsive than the stock one? Would that mean better low end torque?
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
