Basically by using this front pipe and adaptor it replaces the Nissan OEM IW assembly. it will just be the externally gated turbo plus the cost of those parts.
Yes the front pipe can be purchased without the turbocharger, how ever I can't guarantee it fits as the clearance created by the turbine housing will be different. We had to make few adjustments to that one so it stays high above the ground and also not touching the toll shaft or the chassis. If you are in Melbourne PM Abe2 and he should be able to make you one out of his shed.
is there anyway to make the rear housing 'not as thick'? because it limits the space between the turbo and firewall. I can see on your car Stao that the A/C drain has been trimmed off, I prefer not to have it so close.
I can trim in in further by probably 5mms, I've also used large 3.5 inch pipe which took abit of the spacing. for 3 inch pipes it would miss. Having larger front pipe i theory reduces back pressure and results similar effect as having a larger turbine housing without the lag. the differences in torque after 4500RPMs is noticeable.
Below is a one of SS2 in .70 comp housing externally gated with a cnc 3inch Vband, Its going to be installed on a track car with a high mount ext gated setup. hopefully be seeing responsive 350rwkws on e85.
Also billet 25G compressor wheel will be ready soon. I will be converting my current side mount into a Brae high mount setup with a 50mm external gate and a 3.5 inches straight through exhaust on evaluations of the new TDxx series turbochargers as well as further results from current G and SS series.
Hey Stao,
Would it not be a good idea to make the v-band adaptor you show on that SS2 have the internal profile made into a nice conical expansion starting at exactly the turbine exit diameter? I see the nasty step in there and can't help thinking that it would work more nicely as a smooth expansion.
why not have a purpose built rear housing for the v-band arrangement instead of the frankenstein I/W adapter thingamebob
it looks heavy too? and with the extra weight of external gate and plumbing it must be an awful strain on the head/manifold?
+1 for a nice conical exit from the turbine.
The bolt on piece is because the housing Stao uses is a 5 bolt style rear.
What is the point of re-engineering a whole housing when you can just bolt a plate on the back of the one that works? He may spend forever finding a housing that suits the application (and actually works) when a simple interchangeable rear means the one good housing which works well can be used for both internal and external application with only a few bolts. End user gets a benefit in that case also, with ability to swap out.
I think its fine.
I though it was pretty obvious why...
lighter, simpler, and better performance.
surely u can get them from china, they copy everything else.
The housing pictured is genuine Garrett. Have you seen what GCG want for such a thing? Its robbery.
Im sure you can get a copy from China, but that will require testing to make sure it works like the original does.
As has been said, why change something that works and that Stao has put that much R&D into?
Absolutely is robbery, hence the opportunity to compete ;) ,a total redesign of the housing Stao already uses isn't necessary, just a new outer cast to use a vband like the garrett. Comes down to who ever is Stao's supplier, their willingness to adapt, and whether there is enough demand for the product
Sure it can be done, but it all comes down to cost mate.
Someone has to pay for tooling, and in this case the job gets done at a high level of quality for a very good price. Why muck with it?
The Taiwanese MFG's do produce a 3" vband out housing (ala T67) for the GT30 range which im sure Stao could adapt to his turbos. But considering the fact he has done so well with his Type B 5 bolts there would have to be some really MAJOR demand for him to sit and try that housing and then see if he can again optimise it further like he has with the EXISTING HOUSINGS.
Requires fab work and all, when we already have one that works and is available to everyone. Leave it be...
Hey Stao, how much for that bolt on V-band piece?
Ive always wanted to get rid of the change in size of the dump pipe right after the turbo..
Spewing I didnt know that you made these before I got my dump pipe made up and ceramic coated.
Do you think the current setup would be costing me much power?
Ive got the SS3-EG.... I dont really have a pic showing the step but im sure you know what I mean.
As turbine housing concern it needs to satisfy 2x criterias, as it must allow both internal and external waste gating and most importantly must have the correct spacing between the factory manifold and turbine outlet so adaptors can be made that bolts up to factory dump pipe. I went through pretty much all turbine housings in its size and that is the only casting that allows me doing that.
Its got lots of materials on it which made it sort of free style as I can machine in to specs I need it to be as well as machining to fit various types of turbine wheels and bearing housings. Plus with the 5 bolt adaptor I can have that customized into any shapes or patterns for what ever applications. Compare to the TD06 and Taiwan housings, they don't have much of materials on them, pretty thin in walls, just go right through when comes to machining, so very limited applications.
Jarryd: That cnc external gate Vband piece is only $200 delivered. But you might need to modify your dump pipe a little for it to fit.
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 🤔
    • From there, it is really just test and assemble. Plug the adapter cables from the unit into the back of the screen, then the other side to the car harness. Don't forget all the other plugs too! Run the cables behind the unit and screw it back into place (4 screws) and you should now have 3 cables to run from the top screen to the android unit. I ran them along the DS of the other AV units in the gap between their backets and the console, and used some corrugated tubing on the sharp edges of the bracket so the wires were safe. Plug the centre console and lower screen in temporarily and turn the car to ACC, the AV should fire up as normal. Hold the back button for 3 sec and Android should appear on the top screen. You need to set the input to Aux for audio (more on that later). I put the unit under the AC duct in the centre console, with the wifi antenna on top of the AC duct near the shifter, the bluetooth antenna on the AC duct under the centre console The GPS unit on top of the DS to AC duct; they all seem to work OK there are are out of the way. Neat cable routing is a pain. For the drive recorder I mounted it near the rear view mirror and run the cable in the headlining, across the a pillar and then down the inside of the a pillar seal to the DS lower dash. From there it goes across and to one USB input for the unit. The second USB input is attached to the ECUtec OBD dongle and the 3rd goes to the USB bulkhead connected I added in the centre console. This is how the centre console looks "tidied" up Note I didn't install the provided speaker, didn't use the 2.5mm IPod in line or the piggyback loom for the Ipod or change any DIP switches; they seem to only be required if you need to use the Ipod input rather than the AUX input. That's it, install done, I'll follow up with a separate post on how the unit works, but in summary it retains all factory functions and inputs (so I still use my phone to the car for calls), reverse still works like factory etc.
    • Place the new daughterboard in the case and mount it using the 3 small black rivets provided, and reconnect the 3 factory ribbon cables to the new board Then, use the 3 piggyback cables from the daughterboard into the factory board on top (there are stand offs in the case to keep them apart. and remember to reconnect the antenna and rear cover fan wires. 1 screw to hold the motherboard in place. Before closing the case, make a hole in the sticker covering a hole in the case and run the cable for the android unit into the plug there. The video forgot this step, so did I, so will you probably. Then redo the 4 screws on back, 2 each top and bottom, 3 each side and put the 2 brackets back on.....all ready to go and not that tricky really.
    • Onto the android unit. You need to remove the top screen because there is a daughterboard to put inside the case. Each side vent pops out from clips; start at the bottom and carefully remove upwards (use a trim remover tool to avoid breaking anything). Then the lower screen and controls come out, 4 screws, a couple of clips (including 3 flimsy ones at the top) and 3 plugs on the rear. Then the upper screen, 4 screws and a bunch of plugs and she is out. From there, remove the mounting brackets (2 screws each), 4 screws on the rear, 2 screws top and bottom and 3 screws holding in the small plates on each side. When you remove the back cover (tight fit), watch out for the power cable for the fan, I removed it so I could put the back aside. The mainboard is held in by 1 screw in the middle, 1 aerial at the top and 3 ribbon cables. If you've ever done any laptop stuff the ribbon cables are OK to work with, just pop up the retainer and they slide out. If you are not familiar just grab a 12 year old from an iphone factory, they will know how it works The case should now look like this:
    • Switching the console was tricky. First there were 6 screws to remove, and also the little adapter loom and its screws had to come out. Also don't forget to remove the 2 screws holding the central locking receiver. Then there are 4 clips on either side....these were very tight in this case and needed careful persuading with a long flat screw driver....some force required but not enough to break them...this was probably the fiddliest part of the whole job. In my case I needed both the wiring loom and the central locking receiver module to swap across to the new one. That was it for the console, so "assembly is the reverse of disassembly"
