A little more feedback re SS1PU SR20:
I did some private work on the weekend to repair a guys clutch hydros. Afterward I had to road test the car and got to have a direct 'back to back' against my own. The customer had a fairly staple setup, sporting a GT2860RS and the usual mods to his 93 spec 180SX. The disco was realistically maxed out on 98.
I can say with absolute confidence that the said disco spud setup is redundant against the SS1PU. The SS1PU comes alive much easier than the spud, and even though I was only running 13psi at the time (tuned for 20) the spud had NOTHING on the SS1PU for power even though the spud was running the appropriate 20psi. It would be fair to say that the spud feels a little more lively under cruise conditions, but doesn't spin up nearly as quick as the SS1PU when you start to punt it. The spud is more so linear when it starts to pull, right to the point of being on full boost, while the SS1PU is aggressive and will go from cruise to full pelt near instantly once you give it some right foot encouragement.
In the last week I have also compared this to an S15 sporting a 5 speed and 4.3 diff (my car is running a 4.11) and I can still say the uber spool of the fully tuned, VCT enabled, HKS cammed, T28 is still redundant to the spool/power offering of the SS1PU (non VCT).
I hope the above is of value to you guys.
Cheers,
hey guy i have a stock turbo r33 gtst series 2, 2 door and was wondering if you could help me out with getting a bit more power. it is for street use and maybe track not sure yet.
please help me out.
thank you
Thanks for the feedback scott.
please help me out.
thank you
You can send in your stock turbocharger for high flow. that will be a responsive and option for a mild upgrade. Then check Toshi for a ECU remap if you haven't got a ECU.
how do i send in my stock turbo for i high flow and i havnt got my ecu remapped yet. cound you send me links on sites or how to do it please :)
Like i said in the PM man, you need all supporting mods before you put on a turbo... Remove the turbo and courier it to Stao... When you get it back tow it up to DVS JEZ and get a nistune installed and tuned...
what supporting mods will i need other then getting it turned and how much am i looking at to get it sent off and then getting it installed and tuned. sorry i am really new to this ahahahahahhaha
Yes basically email your factory turbocharger in with actuator. I'm pmed you with some instructions.
The stock injectors are ok for around the 230rwkws mark and so's the factory AFM. To get that all you need to do is have:
FMIC kit installed
metal induction pipe and a good pod filter (check M35scotty)
3inch turbo back exhaust with 100cc cat.
Walbro fuel pump
Get stock ecu flashed through Toshi.
If you already bought a aftermarket ecu or we can supply adaptronic ecus with the turbo, you might want to get some injectors, then it can be live tuned through DVSJES or Toshi or Other good tuners.
FMIC kit installed
Walbro fuel pump
:rofl: Good one Stao... ;)
GOD DAMNIT STAO OUTLOOK REFUSES TO ATTACH MY TURBO TO AN EMAIL. THIS IS BULLSHIT.
:D :D :D hahahaha
Hehehehe your turbo must have a vius :ph34r:
Poor Stao needs a coffee i think hehe
Going to the drags tomorrow night.
Fingers crossed I don't embarrass myself or that my unfinished tune doesn't let me down :)
hy_rpm where you at?
Unfinished tune?
14.0 @ 98mph
lol I am fairly confident I will trap more than 98mph, but we will see.
Unfinished tune because unigroup refused to set to kill until it had done a minimum of 1,500km. It was also tuned on a 45 degree day as noted.
Much more to be had, I'm sure. I'm just hoping I can get some boost into it with the cold we're experiencing. It cuts at 18psi on a 25 degree day when it was tuned to cut at 23psi. Gayer than aids.
Haha, I was 50/50 at that point. Am worried I will not be able to flat foot it in 4th due to the boost cut. Tempted to do an actuator pressure run just to get a feel for traction and see how high boost creeps.
I will be stoked with 110mph whist in this tune state :) the motor still has the start-up oil in it after all lol
Spewing can't make it out to the creek got rego to pay first might go to a Sunday street meet next month to test it out
Your car should pull atleast a 118mph if it doesn't cut as that's what I pulled with 230rwkw
Hey stao will a stronger actuator help the atr28g2 to hold boost up top as its currently got a 1bar one and it goes from 25psi to 21psi after 5500rpm or is the turbo maxxed out
I was thinking of getting a kando actuator with a 1.5 bar or 21psi spring or can you supply one how much ?
Edited by hy_rpm
:D :D :D hahahaha
i will reply the turbo back to you once its complete. Sorry, been replying emails since I fell asleep.
Finally got a dyno reading from the latest SS2 internally gated turbo on stock manifold, as a factory replacement. Result sent by a customer, not from my test car.
Been internally gated, It held boost extremely well.
Final reading of:
297.7rwkws @ 20psi. Yellow
278rwkws @ 17psi. Light blue
Dark blue was when the car had various issues to repair before today's tune. (ignore)
I've been told its very fast.
Add: They are on pump 98 fuel. not E85.
    • From there, it is really just test and assemble. Plug the adapter cables from the unit into the back of the screen, then the other side to the car harness. Don't forget all the other plugs too! Run the cables behind the unit and screw it back into place (4 screws) and you should now have 3 cables to run from the top screen to the android unit. I ran them along the DS of the other AV units in the gap between their backets and the console, and used some corrugated tubing on the sharp edges of the bracket so the wires were safe. Plug the centre console and lower screen in temporarily and turn the car to ACC, the AV should fire up as normal. Hold the back button for 3 sec and Android should appear on the top screen. You need to set the input to Aux for audio (more on that later). I put the unit under the AC duct in the centre console, with the wifi antenna on top of the AC duct near the shifter, the bluetooth antenna on the AC duct under the centre console The GPS unit on top of the DS to AC duct; they all seem to work OK there are are out of the way. Neat cable routing is a pain. For the drive recorder I mounted it near the rear view mirror and run the cable in the headlining, across the a pillar and then down the inside of the a pillar seal to the DS lower dash. From there it goes across and to one USB input for the unit. The second USB input is attached to the ECUtec OBD dongle and the 3rd goes to the USB bulkhead connected I added in the centre console. This is how the centre console looks "tidied" up Note I didn't install the provided speaker, didn't use the 2.5mm IPod in line or the piggyback loom for the Ipod or change any DIP switches; they seem to only be required if you need to use the Ipod input rather than the AUX input. That's it, install done, I'll follow up with a separate post on how the unit works, but in summary it retains all factory functions and inputs (so I still use my phone to the car for calls), reverse still works like factory etc.
    • Place the new daughterboard in the case and mount it using the 3 small black rivets provided, and reconnect the 3 factory ribbon cables to the new board Then, use the 3 piggyback cables from the daughterboard into the factory board on top (there are stand offs in the case to keep them apart. and remember to reconnect the antenna and rear cover fan wires. 1 screw to hold the motherboard in place. Before closing the case, make a hole in the sticker covering a hole in the case and run the cable for the android unit into the plug there. The video forgot this step, so did I, so will you probably. Then redo the 4 screws on back, 2 each top and bottom, 3 each side and put the 2 brackets back on.....all ready to go and not that tricky really.
    • Onto the android unit. You need to remove the top screen because there is a daughterboard to put inside the case. Each side vent pops out from clips; start at the bottom and carefully remove upwards (use a trim remover tool to avoid breaking anything). Then the lower screen and controls come out, 4 screws, a couple of clips (including 3 flimsy ones at the top) and 3 plugs on the rear. Then the upper screen, 4 screws and a bunch of plugs and she is out. From there, remove the mounting brackets (2 screws each), 4 screws on the rear, 2 screws top and bottom and 3 screws holding in the small plates on each side. When you remove the back cover (tight fit), watch out for the power cable for the fan, I removed it so I could put the back aside. The mainboard is held in by 1 screw in the middle, 1 aerial at the top and 3 ribbon cables. If you've ever done any laptop stuff the ribbon cables are OK to work with, just pop up the retainer and they slide out. If you are not familiar just grab a 12 year old from an iphone factory, they will know how it works The case should now look like this:
    • Switching the console was tricky. First there were 6 screws to remove, and also the little adapter loom and its screws had to come out. Also don't forget to remove the 2 screws holding the central locking receiver. Then there are 4 clips on either side....these were very tight in this case and needed careful persuading with a long flat screw driver....some force required but not enough to break them...this was probably the fiddliest part of the whole job. In my case I needed both the wiring loom and the central locking receiver module to swap across to the new one. That was it for the console, so "assembly is the reverse of disassembly"
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
