Sorry if I missed it but what tyres did you run? Good result with potential, bring on the 11s!
Pretty sure he said MickyTs somewhere :)
Tested the atr28g2 on the 180sx today at wsid
Was very busy and only managed one decent run
On 20psi boost got 12.4 at 120mph shit 60ft 2.2 had abit if wheel spin on launch
Tried high boost 24psi but blew a cooler hose off and ruined the run also track temps were 30c in the middle of the day
Will be definately heading back in a few weeks on a Wednesday night when it's cooler and hopefully crack that Dam 11s
Still got 4-5psi in it so maybe 20kw and will let down the Tyres down more as I got et streets and was on 30psi try 25 or less psi
Very nice -that is on E85, right? That has definite 11s potential, especially on high boost!
Ah sweet, thanks :D
Yeah eflex and et streets
Awesome! What size are you running out of curiosity? (I will be getting the same tyre eventually!)
255/50/16 on 300zx stockies
The difference they make is massive
If you thought you car was fast before once you try these you will be amazed
You can flat foot it in first gear and smash it in second no wheel spin at all just a chirp
Nice! And yeah i have been told getting grip through the first couple of gears really makes it feel like a different car, i cant get mine off the line no matter what i try so to have this sort of grip would just be nuts!!! :woot: well done.... Oh, much of a burnout prior to the run?
As if his answer is going to stop you doing a burnout! :P
Shhhh :ph34r: was just hoping it would be justified :P
LOL Do a little one Matt. Just enough to get the crap off your tyres and get a tiny bit of heat into them.
The drive back from the end of the strip is through the burnout patch so you pick up heaps of shit box grubbyness and bits of rooted rubber.
Just do a little one to get SOME heat into the tyres and clean the crap off. Don't pinch the brakes too hard though, or you will fry the VLSD like I did on my 13.0 pass :) Single pegged off the line.
No single pegging with the Nismo but thanks for the tips ;)
I found tyre pressure had more of an effect than length of burnout for myself. When doing a burnout I'd just keep it going until the rears started really pushing the car forward, or if I've head a couple of seconds of solid smoke - whichever came first... then slowly let it creep then release the brake and just nail the throttle because it's fun and you get a bit of a hint of what kind of hook up you may get when you launch, to decide how hard to feed it to it off the line.
You know if i do this i am likely to end up in the grandstand? :P
Lol I don't mean keep in it for ages :P Just enough to get a launch off your burnout then get off it again before you end up in a tree/grandstand/half way up the dragstrip ;)
I only have a shimmed stock VLSD and normal street tyres on mine, so a big dirty burnout like that was more likely to cook the oil in the diff or make the tyres really greasy lol
What was really fail for me is that I had good traction on my first 2 runs but had bad boost cut, and on my cleanest run I spun like an idiot lol.
Lol I was clearly addressing his question regarding warming up the MTs :P Besides, if you have the power to run 120mph+ on road tyres with a RWD then you are clearly just there for the burnouts!
Oh wait, 114mph... nvm ;)
LOL 115 thank you very much!
As a response to this comment I have emailed unigroup about a time to bring the car in and amend the tune :P I will see if it can be done on a Wednesday so I can make the most of the trip ;)
:laugh:
:rofl:
:whistling:
Awesome - I am sure you'll keep us updated :)
Might be a good idea to see if VCT can be enabled in your S14, that makes a very noticeable difference in how the car behaves down low, they appears to work fine with Tomei drop in Pon cams.
Some video footages from David at the latest Stadium drift competition at Wakefield NSW.
Its a Laurel with Rb25det and our standard high flow profiled turbocharger. Tuned by Toshi.
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
