  • Replies 615
Posted Images
All going to plan, these should be on by the end of the week, and I should have some nice brakes to post up too :happy:
What upper arms are you going to use on the front? I have the Ikeya LCA kit but still undecided on what to use for the uppers.
Nice work on the build and thanks for constant updates. :(
haha, seems fats is doing the rain dance...i might have to put my wipers on.
how are you looking?
:rofl::):blink:
Errrrmmmm... I don't actually have wipers on the car, and I have NO idea where they are :huh:
Will have a better idea on whether or not I'll make it by about Thursday 8pm :bunny:
Nice work on the build and thanks for constant updates. :bunny:
Thanks mate :rofl:
I have Cusco ones (-10mm), as I like the idea of fixed length parts... I just don't trust those "silk road" or "midori" style sliding ones.
...but I'll see how I go... I might change to UAS pivoting upper arms sometime in the future...
Mmmm... Nice power curve!
All on a stock engine!!! :P
Nice curve Andrew.
Dont feel you need to blank out the number though, there's no shame in having a GTR in the 200's hahaha
Still -7's?
So this means we'll be seeing you on Friday then...?
Here's GT-RS's as a comparison for you
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
